Misterious errors
Every now and then I get two errors in the log which I cannot address and so cannot repair.
They are comming mostly at (about) te same time.
Can anybody help?
The errors:
Logger: homeassistant
Bron: helpers/service.py:822
Eerst voorgekomen: 14:37:00 (12 gebeurtenissen)
Laatst gelogd: 19:38:00
Error doing job: Task exception was never retrieved (None)
  File "/usr/src/homeassistant/homeassistant/components/template/coordinator.py", line 140, in _handle_triggered_with_script
    if script_result := await self._script.async_run(run_variables, script_context):
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1833, in async_run
    return await asyncio.shield(create_eager_task(run.async_run()))
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 460, in async_run
    await self._async_step(log_exceptions=False)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 526, in _async_step
    self._handle_exception(
        ex, continue_on_error, self._log_exceptions or log_exceptions
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 556, in _handle_exception
    raise exception
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 524, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1009, in _async_step_call_service
    response_data = await self._async_run_long_action(
    ...<9 lines>...
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 624, in _async_run_long_action
    return await long_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 2816, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2859, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 822, in entity_service_call
    raise HomeAssistantError(
        "Service call requested response data but did not match any entities"
homeassistant.exceptions.HomeAssistantError: Service call requested response data but did not match any entities
And also:
Logger: homeassistant.helpers.script.trigger_update_coordinator
Bron: helpers/script.py:2064
Trigger Update Coordinator: Error executing script. Error for call_service at pos 3: Service call requested response data but did not match any entities
