Mitsubishi Wifi Module WF-RAC (Smart M-Air)
I’m seeing the same crashing behaviour. Though in my case it looks more like a complete freeze rather than crash (nothing in logs, but actual process is still running).
I can confirm it’s definitely an issue. I ended up completely replacing the hardware HA is running on, changing the raspberry pi for a mini pc. There was a big increase in performance and responsiveness of home assistant, but I’m still seeing the same behaviour when turning on or off the aircon units. As you say, it’s more like the whole system freezes and I have to force a restart of HA core. I’m also not seeing anything useful in the logs, even though I’ve enable debug logging.
@jeatheak Is there a way you can fix this issue? It’s very frustating to route all commands to NodeRed. I use a complex MQTT Routing which should not be uses because of you integration …
Does anyone know that if MHICAD-WF100 (new version of WF-RAC) work with this module? Thanks!
DId you ever figure it out?
Did you ever figure it out?
So I’m still having issues with the WF-RAC devices.
They’re still performing ARP changes every hour, setting their IP address to the same as my Gateway and announcing it causing every device connected on the network to assume the WF-RAC is now the main gateway device.
Turning on ARP spoofing has worked but it shouldn’t be necessary, really.
