I want to exchange the last is_state (in between the pairs of “**”) to a condition:time before: 05:10, how would that like like?
data_template:
value: >-
{% if is_state('timer.upper_hall_way_3_min', 'idle') and **is_state('input_boolean.away_mode', 'on'**`)%}`
123
(Taras)
2
The following means (time < 05:10) AND (away_mode == on)
condition:
- condition: time
before: '05:10'
- condition: state
entity_id: 'input_boolean.away_mode'
state: 'on'
If you prefer to explicitly indicate it is an AND operation, you can write it like this:
condition:
condition: and
conditions:
- condition: time
before: '05:10'
- condition: state
state: 'on'
Thanks for replying, but I think that will not help me, since it is part of a big if-statement:
data_template:
value: >-
{% if is_state('timer.upper_hall_way_3_min', 'idle') and is_state('input_boolean.away_mode', 'on')%}
scene.huset_natter_away
{% elif is_state('timer.upper_hall_way_3_min', 'active') and is_state('input_boolean.away_mode', 'on')%}
scene.sensor_upper_hall_way_nights_on_away
{% elif is_state('timer.upper_hall_way_3_min', 'active') and is_state('input_boolean.away_mode', 'off')%}
{% elif is_state('timer.upper_hall_way_3_min', 'active') and **is_state('input_boolean.away_mode', 'off'**)%}
scene.house_nights
{% else %}
scene.house_no_change
{% endif %}
123
(Taras)
4
Without seeing the entire automation, or knowing what is your ultimate goal, it’s difficult to provide you with additional assistance.
Good luck adding a time constraint to the automation.
petro
(Petro)
5
You need to convert the current time and the value to check against into a common number. Doesn’t matter what, hours, minutes, or seconds.
Time conversions
hours |
hours |
minutes / 60 |
seconds / 3600 |
minutes |
hours * 60 |
minutes |
seconds / 60 |
seconds |
hours / 3600 |
minutes / 60 |
seconds |
Here is the comparison using hours as the common time units:
{% set current_time = now().hour + now().minute / 60 + now().second / 3600 %}
{% set t510 = 5 + 10 / 60 %}
{% if is_state('timer.upper_hall_way_3_min', 'idle') and current_time < t510 %}
Inside your yaml:
data_template:
value: >-
{% elif is_state('timer.upper_hall_way_3_min', 'active') and current_time < t510 %}
scene.house_nights
{% else %}
{% endif %}
ahh, that I would not have figured out myself, thanks a lot!
/Martin
