ML Energy Consumption Forecaster - Schedule Loads around Solar Surplus
With solar panels it's not enough to know when the sun will shine — you also need to know when your household will consume. I built a Home Assistant app that predicts hourly energy consumption 48 hours ahead, trained entirely on your own HA meter history. No cloud service, no generic averages — it learns your household's patterns (daily routines, heat pump cycles, seasonal swings) and publishes them as standard HA sensors.
My main use case is feeding the forecast into a companion app, which combines it with a solar production forecast to compute expected surplus and automatically schedule deferrable loads. But the sensors also work directly in HA automations — energy_forecast_tomorrow and the 3-hour block sensors are enough for a threshold-based scheduling rule.
A few things that make it more than a basic forecast:
  • Scenario API: "what if I run the dishwasher at 14:00?" returns the delta against the baseline
  • SHAP explainability: know why the model predicted high consumption today
  • Rolling 7d/30d MAE sensors to track real-world accuracy over time
  • Physics-informed features: thermal pressure, DHW tank pressure, infiltration load, defrost risk
  • Works on Raspberry Pi (automatic LightGBM → scikit-learn fallback)
I've set up GitHub Discussions if you want to compare accuracy or share how you're using it: What's your MAE? · How are you using it?
