Mochad repository and replacement
Hi, not sure when this started, but I’m seeing a message in my Settings that says I have a Repair Issue and that mochad is no longer in the original repository. Everything still works, just trying to follow its advice and remove/replace the code.
Beyond dropping my X10 use, which still works in my house for my needs, is there a software replacement path that’s ‘recommended’?
Thanks.
