I need to get the result of reading two registers:
With ModbusDoctor the result is correct, but how can I get the result using home assistant?
It might work like the following syntax:
- name: "Usage Water"
unique_id: "water_usage"
address: 1583
data_type: uint32
input_type: input
count : 2
scale: 1
precision: 1
slave: 1
Register 1583 contains: 2324
Register 1584 contains 1
combined should return: 67860
I tryed using data_type: custom but didn’t get the right result. What do I have to do?
