Solaredge Modbus Multi added as integration in Home-assitant. In got an error:
Setup failed, retrying: Modbus Error: Illegal size (3) of register array, cannot convert.
can anyone help to solve it?
thanks
thanks
Problem solved.
Deleted “Solaredge ModBus”
Yes, you have to delete “solaredge modbus” integration. It’s not kept up to date and causes newer integrations (including modbus core integration) to break.
Version 3.1.2 of SolarEdge Modbus Multi will check for old versions of pymodbus other integrations might load and log a message telling you to remove them.
