Modbus Heatpump Gonzik
Hello, I have added a modbus via serial RS485 to my home assistant. My information is rather old. I am wondering if there are more variables available, especially volume values and with it heat capacity values.
Hello nicGoSan,
Thanks for coming here and asking a question.
Would you be so kind as to adjusting the format of your code so that we can read it properly & check the YAML spacing, etc. Editing your original is the preferred way. It is very hard for us to tell what is what when the text formatter jumbles everything like that.
Use the </> button or this:
Here is an example of how to fix it from the site FAQ Page.
How to help us help you - or How to ask a good question.
Hi, I have a 7 page document with adresses and other data. Currently I can’t find the time to dive into this, but maybe we can help each other with this :slight_smile: Let met know your thoughts
Very Cool. Do you have a PHNIX Greentherm? I also tried to hookup a MODBUS-Dongle. Reading registers work, but writing is not possible. @Herbertnl You seem to have a complete MODBUS Register list. This is awesome. Is this publicly available? I Have found out several Registers by try-and-error (changing some parameters forth and back and then see which registers changed by sniffing on the MODBUS). E.g. These:
1001,“Serial Number 1/7 [hex]”
1002,“Serial Number 2/7 [hex]”
1003,“Serial Number 3/7 [hex]”
1004,“Serial Number 4/7 [hex]”
1005,“Serial Number 5/7 [hex]”
1006,“Serial Number 6/7 [hex]”
1007,“Serial Number 7/7 [hex]”
1010,“Bank base”
1011,“Power on/off [0=off,1=on]”
Then it seems to continue with your list.
Sources: Wäremepumpe (The manuals are from 2021 and seem to be outdated/old version ?)
Sir im trying to connect like you. But i dont get any data. Can you show me what is your connection. Slave address is decimal 10. 10 is right? Sir
i’ve send pm
Have you successfully integrated the heat pump? I’m also interested in a solution.
There is this Warmlink integration that I use for my Phnix limited but works for basic stuff GitHub - 00gtw00/homeassistant_warmlink: Warmlink is a custom Home Assistant integration for Warmlink/LinkedGo heat pumps. It logs in to the cloud, reads status and temperatures (Outlet is current temp), lets you set target temperature, and turn heating on/off. Use the main cloud account in HA; the mobile app should use a separate email with a shared Home to avoid single-login kicks. OK!!
