Modbus Hitachi CSNET lite
Hi, I bought a Hitachi CSNET lite to remotely manage the air conditioners, it has the Modbus tcp protocol inside and I would like to use this function to integrate it into HA. Could I get your assistance to write the code? Or if there is already a realized project. Thank you
Processing: Hitachi_csnet_lite_register_list.pdf…
I managed to write this code, it works but several functions are missing, such as the current temperature, if I remove the # HA it gives me an error. What it means
modbus:
  - name: Hitachi
    type: tcp
    host: 192.168.2.237
    port: 502
    climates:
      - name: Clima 201
        unique_id: clima_201
        slave: 1
        address: 1
        input_type: holding
        count: 1
        max_temp: 30
        min_temp: 18
        offset: 0
        precision: 1
        target_temp_register: 20006
        temp_step: 1
        temperature_unit: "°C"
        hvac_mode_register:
          address: 20004
          values:
            state_cool: 0
            state_heat: 3
          write_registers: true
        hvac_onoff_register: 20003
Now with this setting I can also get the current room temperature, but I think this code can be written better. I also had to insert a switches to be able to turn the climate on and off, I was unable to insert it as an integral part of the climate. If anyone more experienced than me has any suggestions, they are welcome. Thank you
modbus:
  - name: hub1
    type: tcp
    host: 192.168.2.237
    port: 502
    switches:
        - name: Power_Clima_201
          address: 20003
          command_on: 1
          command_off: 0
    climates:
      - name: Clima 201
        slave: 1
        address: 20015
        input_type: holding
        count: 1
        max_temp: 30
        min_temp: 18
        offset: 0
        precision: 1
        temp_step: 1
        hvac_mode_register:
          address: 20004
          values:
            state_cool: 0
            state_heat: 3
Hi!
Where did you manage to find this product?
The product is sold by Hitachi dealers, they order it for you, I also found an online dealer in Italy who ordered it for me, it costs more than €1,000.00 but I can now manage 28 climates.
Is the lite better than A{x}MB?
Would contact you directly but there is no message option in here.
I don’t know what you’re telling me
I was talking about A128MB model, which I acquired in the meantime.
Right now I have it like this, slightly altered after this docs:
configuration.yaml:
modbus: !include modbus.yaml
modbus.yaml
- name: hub1
  type: tcp
  host: 192.168.1.122
  port: 502
  switches:
    - name: Hitachi
      address: 20003
      command_on: 1
      command_off: 0
      verify:
        input_type: holding
        address: 20009
        state_on: 1
        state_off: 0
    - name: "Hitachi Low / Medium"
      address: 20005
      command_on: 1
      command_off: 0
      verify:
        input_type: holding
        address: 20010
        state_on: 1
        state_off: 0
    - name: "Hitachi Low / High"
      address: 20005
      command_on: 2
      command_off: 0
      verify:
        input_type: holding
        address: 20005
        state_on: 2
        state_off: 0
    - name: "Hitachi Low / High2"
      address: 20005
      command_on: 3
      command_off: 0
      verify:
        input_type: holding
        address: 20005
        state_on: 3
        state_off: 0
    - name: "Hitachi Low / Auto"
      address: 20005
      command_on: 4
      command_off: 0
      verify:
        input_type: holding
        address: 20005
        state_on: 4
        state_off: 0
  climates:
    - name: Hitachi
      unique_id: hitachi
      slave: 1
      address: 20015
      input_type: holding
      count: 1
      max_temp: 30
      min_temp: 18
      offset: 0
      precision: 1
      temp_step: 1
      hvac_mode_register:
        address: 20004
        values:
          state_cool: 0
          state_dry: 1
          state_fan_only: 2
          state_heat: 3
          state_auto: 4
Because SET_FAN is not available (yet) in modbus climate, at least there are buttons for changing speed, and it also reads the on/off status + there are fan, cool, dry, auto and off modes too.
I will keep perfecting it, want to try another solution for speed selection etc, and will keep you posted.
I created this as a solution to the modbus controlled air conditioning fan speed
#=== Input Numbers
input_number:
  fan_air_conditional_101:
    min: 0
    max: 2
    step: 1
    icon: mdi:air-conditioner
#=== ModBus
modbus:
  - name: hub1
    type: tcp
    host: 192.168.2.237
    port: 502
    climates:
      - name: Clima 101
        unique_id: clima_101
        #hub: hub1
        slave: 1
        address: 20239
        input_type: holding
        count: 1
        max_temp: 30
        min_temp: 18
        offset: 0
        precision: 1
        #structure: ">10h"
        target_temp_register: 20230
        temp_step: 1
        hvac_mode_register:
          address: 20228
          values:
            state_cool: 0
            state_heat: 3
        hvac_onoff_register: 20227
    sensors:
      - name: Fan State 101
        unit_of_measurement: status
        slave: 1
        address: 20235
        input_type: holding
#=== Automations
automation:
  #=== Write the input value on the modbus
  - alias: Fan 101
      - platform: state
        entity_id:
        - input_number.fan_air_conditional_101
    condition: []
      - service: modbus.write_register
          hub: hub1
          address: 20229
          value: '{{ states.input_number.fan_air_conditional_101.state|int }}'
          hub: hub1
          address: 20235
  #=== Check the fan speed sensor value, if it is different change the input
  - alias: State Fan 101
      - platform: state
        entity_id:
        - sensor.fan_state_101
    condition: []
      - service: input_number.set_value
        data_template:
          entity_id: input_number.fan_air_conditional_101
          value: "{{ states.sensor.fan_state_101.state | int }}"
sorry for my dumb questions as Iam relatively new to modbus but what is
sensors:
  - name:
    slave: 1
    address: 20235
    input_type: holding
referring to ? I cant find the register in the documentation
It should be described in the modbus documentation of your device.
