Modbus - platform Climates wrong
I have the following problem with modbus configuration in Home Assistant. Reading the temperature sensors via the modbus works fine, while when I try to run the thermostat, the system says that the syntax is wrong. What could be the problem?
my entry in configuration.yaml
modbus:
  • type: tcp
    host: 192.168.1.19
    port: 8899
    sensors:
    • name: Room1
      slave: 1
      address: 200
      input_type: holding
      unit_of_measurement: °C
      count: 1
      scale: 0.1
      offset: 0
      precision: 1
      data_type: uint
      scan_interval: 120
    • name: Room2
      slave: 1
      address: 202
      input_type: holding
      count: 1
      scale: 0.1
      offset: 0
      precision: 1
      data_type: uint
      scan_interval: 120
      climates:
    • name: “Watlow F4T”
      slave: 1
      address: 200
      input_type: holding
      count: 1
      data_type: custom
      max_temp: 25
      min_temp: 15
      offset: 0
      precision: 1
      scale: 0.1
      structure: “>f”
      target_temp_register: 50
      temp_step: 1
      temperature_unit: C
error:
Invalid config for [modbus]: Structure request 4 bytes, but 1 registers have a size of 2 bytes @ data[‘modbus’][0][‘climates’][0]. Got OrderedDict([(‘name’, ‘Watlow F4T’), (‘slave’, 1), (‘address’, 200), (‘input_type’, ‘holding’), (‘count’, 1), (‘data_type’, ‘custom’), (‘max_temp’, 25), (‘min_temp’, 15), (‘offset’, 0), (‘precision’, 1), (‘scale’, 0.1), (‘structure’, ‘>f’), (‘target_temp_register’, 50), (‘temp_step’, 1), (‘temperature_unit’, ‘C’), (‘scan_interval’, 15)]). (See /config/configuration.yaml, line 18).
