Modbus results in initialization error and warning of no entities
I have a wattnode energy meter attached to my main panel and connected to my linux computer with a usb to rs485 device. I used python to retrieve two sets of information and print it out with tkinter, successfully. I plugged the usb in to my home assistant computer (running hassio) and am trying to do the same thing, but I can’t get the modbus to communicate.
This was how I connected successfuly with python:
try:
client= ModbusSerialClient(port=“/dev/ttyUSB0”, timeout=20, baudrate=9600, bytesize=8, parity=“N”, stopbits=1)
client.connect()
and retrieved the information with this code
Power=client.convert_from_registers(client.read_holding_registers(address=1168, count=2, slave=1).registers, client.DATATYPE.FLOAT32, ‘little’)
Power=round(Power/1000,3)
Instant=client.convert_from_registers(client.read_holding_registers(address=1008, count=2, slave=1).registers, client.DATATYPE.FLOAT32,‘little’)
Instant=round(Instant/1000,3)
So now I am trying to get modbus to work on home assistant and started with one sensor to test it, but everytime I restart HA I get these two notices:
Modbus Wattnode contain no entities, causing instability, entry not loaded
Setup failed for ‘modbus’; integration failed to initialize
This is the code i put in the yaml configuration file
modbus:
  • name: Wattnode
    type: serial
    method: rtu
    port: /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_B001K6T8-if00-port0
    baudrate: 9600
    stopbits: 1
    bytesize: 8
    parity: N
    Sensors:
    • name: Instantaneous_Power
      slave: 1
      #value_type: fp32_r
      address: 1008
      input_type: input
      unit_of_measurement: W
      data_type: float32
      count: 2
      scan_interval: 10
Check out if this Protocol Wizard can assist?
Thank you! I just started with Home Assistant, and it took me a few houres just to figure out how to set up hacs and access this wizard, but once I did the result was a success. Now I can relax and figure out yaml at a more leisurely pace to understand what I was doing wrong in trying to connect to modbus.
