Modbus RTU - connection problem if more than one connected device
Good morning,
When I have only one device connected on modbus RTU than everything works fine.
When three of them are connected (the same devices) through Modbus RTU than my entities are unavalable.
What could be the problem?
Code:
modbus:
  - name: hub1
    type: serial
    method: rtu
    port: /dev/ttyUSB0
    baudrate: 19200
    stopbits: 1
    bytesize: 8
    parity: N
    timeout: 30
    delay: 20
    retry_on_empty: true
    close_comm_on_error: false
    retries: 5
    sensors:
      - name: "inv01 org Work state"
        scan_interval: 40
        data_type: int16
        slave: 6
        address: 25288
Code for multiple connections:
modbus:
  - name: hub1
    type: serial
    method: rtu
    port: /dev/ttyUSB0
    baudrate: 19200
    stopbits: 1
    bytesize: 8
    parity: N
    timeout: 10
    delay: 5
    retries: 5
    sensors:
        scan_interval: 5
        data_type: int16
        slave: 6
        address: 25288
  - name: hub2
    type: serial
    method: rtu
    port: /dev/ttyUSB1
    baudrate: 19200
    stopbits: 1
    bytesize: 8
    parity: N
    timeout: 10
    delay: 5
    retries: 5
    sensors:
      - name: "inv02 org Work state"
        scan_interval: 5
        data_type: int16
        slave: 6
        address: 25288
If you can change slave id. You only need one adapter
hey did u ever figure this out???
