Modbus/siemens logo problems after latest update
i have a homeassistant running on a raspberry pi.
the configuration contains modbus links to siemens logo.
After the latest update of HA i get the status but can’t trigger the relais (coils).
in the previous version it works like a charm.
I know the configuration has changed but i can’t seem to get it to work in the new version.
Can someone help me?
current config :
modbus:
  • name: Stalling
    type: tcp
    host: 192.168.XX.17
    port: 504
  • name: Berging
    type: tcp
    host: 192.168.XX.18
    port: 505
  • name: Zolder
    type: tcp
    host: 192.168.XX.19
    port: 504
  • name: Brievenbus
    type: tcp
    host: 192.168.XX.20
    port: 502
switch:
  • platform: modbus
    coils:
    • name: autos
      hub: Stalling
      slave: 3
      coil: 8256
    • name: stalling
      hub: Stalling
      slave: 3
      coil: 8257
    • name: bypass
      hub: Stalling
      slave: 3
      coil: 8258
    • name: lavabo
      hub: Zolder
      slave: 2
      coil: 8256
    • name: douche
      hub: Zolder
      slave: 2
      coil: 8257
    • name: speelkamer_trap
      hub: Berging
      slave: 1
      coil: 8256
    • name: projector
      hub: Berging
      slave: 1
      coil: 8257
    • name: slaapkamer
      hub: Berging
      slave: 1
      coil: 8258
    • name: eiland
      hub: Berging
      slave: 1
      coil: 8260
    • name: dampkap
      hub: Berging
      slave: 1
      coil: 8261
Any help is much appreciated.
Thanks,
Dennis
try formating you code so we can read it
default_config:
tts:
  • platform: google_translate
xiaomi_aqara:
gateways:
  • host: 192.168.XX.147
    mac: ------
    key: --------
media_player:
  • platform: emby
    host: 192.168.XX.254
    api_key: -----------------
nest:
client_id: ----------
client_secret: ------------
project_id:--------------------
subscriber_id: --------------------
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: false
login_attempts_threshold: 5
modbus:
  • name: Stalling
    type: tcp
    host: 192.168.XX.17
    port: 504
  • name: Berging
    type: tcp
    host: 192.168.XX.18
    port: 505
  • name: Zolder
    type: tcp
    host: 192.168.XX.19
    port: 504
  • name: Brievenbus
    type: tcp
    host: 192.168.XX.20
    port: 502
input_boolean:
autos:
stalling:
lavabo:
douche:
speelkamer_trap:
projector:
slaapkamer:
eiland:
dampkap:
living_indirect:
tafel_algemeen:
buiten_voor:
eettafel:
trap:
inkom:
living:
buiten_achter:
hekken:
ventilatie:
trap2:
bypass:
pad:
switch:
  • platform: modbus
    coils:
    • name: autos
      hub: Stalling
      slave: 3
      coil: 8256
    • name: stalling
      hub: Stalling
      slave: 3
      coil: 8257
    • name: bypass
      hub: Stalling
      slave: 3
      coil: 8258
    • name: lavabo
      hub: Zolder
      slave: 2
      coil: 8256
    • name: douche
      hub: Zolder
      slave: 2
      coil: 8257
      hub: Berging
      slave: 1
      coil: 8256
    • name: projector
      hub: Berging
      slave: 1
      coil: 8257
    • name: slaapkamer
      hub: Berging
      slave: 1
      coil: 8258
    • name: eiland
      hub: Berging
      slave: 1
      coil: 8260
    • name: dampkap
      hub: Berging
      slave: 1
      coil: 8261
    • name: living_indirect
      hub: Berging
      slave: 1
      coil: 8262
    • name: eettafel
      hub: Berging
      slave: 1
      coil: 8276
    • name: keuken_indirect
      hub: Berging
      slave: 1
      coil: 8264
    • name: tafel_algemeen
      hub: Berging
      slave: 1
      coil: 8265
    • name: buiten_voor
      hub: Berging
      slave: 1
      coil: 8266
    • name: trap
      hub: Berging
      slave: 1
      coil: 8267
    • name: inkom
      hub: Berging
      slave: 1
      coil: 8268
    • name: living
      hub: Berging
      slave: 1
      coil: 8269
    • name: buiten_achter
      hub: Berging
      slave: 1
      coil: 8270
    • name: hekken
      hub: Berging
      slave: 1
      coil: 8271
    • name: ventilatie
      hub: Berging
      slave: 1
      coil: 8272
    • name: trap2
      hub: Berging
      slave: 1
      coil: 8275
    • name: pad
      hub: Brievenbus
      slave: 4
      coil: 8256
binary_sensor:
  • platform: modbus
    scan_interval : 2
    coils:
    • name: pad
      hub: Brievenbus
      slave: 4
      coil: 8193
      device_class: light
    • name: autos
      hub: Stalling
      slave: 3
      coil: 8192
      device_class: light
    • name: stalling
      hub: Stalling
      slave: 3
      coil: 8193
      device_class: light
    • name: bypass
      hub: Stalling
      slave: 3
      coil: 8259
    • name: lavabo
      hub: Zolder
      slave: 2
      coil: 8192
      device_class: light
    • name: douche
      hub: Zolder
      slave: 2
      coil: 8193
      device_class: light
      hub: Berging
      slave: 1
      coil: 8192
      device_class: light
    • name: projector
      hub: Berging
      slave: 1
      coil: 8193
      device_class: light
    • name: slaapkamer
      hub: Berging
      slave: 1
      coil: 8194
      device_class: light
    • name: eiland
      hub: Berging
      slave: 1
      coil: 8196
      device_class: light
    • name: dampkap
      hub: Berging
      slave: 1
      coil: 8197
      device_class: light
      hub: Berging
      slave: 1
      coil: 8198
      device_class: light
    • name: eettafel
      hub: Berging
      slave: 1
      coil: 8199
      device_class: light
      hub: Berging
      slave: 1
      coil: 8200
      device_class: light
      hub: Berging
      slave: 1
      coil: 8201
      device_class: light
    • name: buiten_voor
      hub: Berging
      slave: 1
      coil: 8202
      device_class: light
    • name: trap
      hub: Berging
      slave: 1
      coil: 8203
      device_class: light
    • name: inkom
      hub: Berging
      slave: 1
      coil: 8204
      device_class: light
    • name: living
      hub: Berging
      slave: 1
      coil: 8205
      device_class: light
      hub: Berging
      slave: 1
      coil: 8206
      device_class: light
    • name: hekken
      hub: Berging
      slave: 1
      coil: 8207
      device_class: light
    • name: ventilatie
      hub: Berging
      slave: 1
      coil: 8208
      device_class: light
    • name: trap2
      hub: Berging
      slave: 1
      coil: 8211
      device_class: light
camera:
  • platform: generic
    still_image_url: -------------
    stream_source: “rtsp://---------------------channel=2&subtype=0”
    verify_ssl: false
    username: ------
    password: -------
    authentication: digest
  • platform: generic
    still_image_url: --------------
    stream_source: “rtsp://a------------channel=1&subtype=1”
    verify_ssl: false
    username: ----------
    password: -----------
  • platform: generic
    still_image_url: ----------------
    stream_source: “rtsp://a------------------channel=1&subtype=1”
    verify_ssl: false
    username: -----------
    password: -------------
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
Hi @DennisS ,
Before updating your HA instance, it’s recommended to go through the release notes. It can save you a lot of time. The team does a very good job in documenting all breaking changes linked to a release.
In the release 2021.6, a breaking change in the Modbus integration was announced.
Link: 2021.6: A little bit of everything - Home Assistant
The configuration style has changed, to secure against illegal configurations.
