Modbus TCP 32 Input board
I have bought an 32 Input board. I would link the input to my Homeassistant as a Door Contact maybe.
But the manuall is all in China.
Can anyone help me? Maybe a member who had also the same board.
https://www.aliexpress.com/snapshot/0.html?spm=a2g0o.9042647.6.2.7b214c4dl89Un5&orderId=3013931948559819&productId=4000650955936
I had the Modul in my network with an local IP adress.
Example: Read 32-way DI, module address = 1:
Modbus TCP format: Hexadecimal
Host sends: 00 00 00 00 00 00 06 01 02 00 00 00 20
Slave Answer: 00 00 00 00 00 00 07 01 02 04 03 FF 01 02
Message Details:
Format of messages sent by the host:
Send content The number of bytes Send messages remark
Protocol header 5 0 0 0 0 0 Fix all to 0
The following number of bytes 1 06 The number of text sections is reported later
Module address 1 01H Module address = 1
Function code 1 02H Read registers <READ_STATE>
The start register address 2 0000H 0000H - This register corresponds to the switching state of DI0 < the > of the 10001 register
The register address is located in the 1zone|
|The number of read registers|2|0020H|Reads the > of registers < 10001-10032 registers for 24 switch inputs
Data send order: high bytes in the front, such as 0020,first:00|
Message format for slave answer:
The following number of bytes 1 04 The number of text sections is reported later
Returns the byte length 1 04H
Returns data 4 03FF0102H 03 From low to high represents the input state of DI0-DI7
03 indicates: DI-0, DI-1 high level ON, other low level OFF
The FF from low to high represents the input state of the DI8-DI15
FF means: DI-8–DI-15 All High Level ON
01 From low to high represents the input state of the DI16-DI123
01 means: DI-16 high level ON, other low level OFF
02 From low to high represents the input state of the DI24-DI31
02 indicates: DI-25 high level ON, other low level OFF|
I can read the data with ModScan. So the connection works.
02: Input Status 10005 1
Who can I read the Input like a Door or a Window?
