I tried different ways but the result was not satisfactory. This is probably because I am a complete beginner when it has to do with Modbus. I hope you can help me in a fairly simple way.
I have received a table with all the important data from the manufacturer CTA. For example, the following settings should be used for the outside temperature:
I do receive some data but the values are by fare not correct. The outside temperature is 8°C and the received values are 10747712, 7667520, 1075183424,âŚ
Iâve got the datasheet directly from the technical customer service by CTA. Theyâre very friendly and you just have to commit that you donât publish it.
What hardware do you need to connect the HA to the CTA via modbus?
I currently have HA on a RPi and am now investigating how I can integrate my CTA heatpump. As I also am registered on the heatpump24 portal, this might be another option, but I guess modbus would be easierâŚ
On the heatpump side: Did you need to set additional parameters? I can reach my CTA heatpump via the browser accessing the inbuilt web server. But I do not receive an answer via modbus so far.
I do not think any additional hardware is necessary: Your HA will communicate via TCP with the heatpump. Did you try to reach it via the web browser? You can just type in the IP address and it should open a login dialog. The default passcode is 999999.
I had already connected the heatpump with my router (normal LAN-Cable). In your router configuration you will find the correct IP-Adress. It should work with the modbus integration and the above mentioned configuration.
Merci, thanks for supplying you config, it works for me. As I have a CTA with TWW, I would like to add the address(es) for âused energy TWWâ, do you know which address that is hidden? (an d can post it to here or to me)?.
I had two calls with support and marketing CTA and they do not give me the modbus interface definition. This is âcompany owner decision not to give that outâ. I buy a expensive device and do not get the info to use it 100%, what a shame. Shame on them.
Yes, I know. That makes it very difficult for us. Here are the the TWW addresses:
Input Register:
2010: TWW Temperatur in °C
2012: TWW Ladefßhler °C
2022: TWW Temperatur unten in °C
Hi Buddeli, thank you very much for the additional details!
In the meantime, I made significant progress and was able to integrate CTA heat pump controls into HA so I can change modes, turn on/off freecooling, and set the comfort temperatures. I was, however, not able to locate the registers to set the reduced temperatures, which for me is not an issue since I rarely change the temperatures. The communication works bidirectionally between HA and the heat pump.
For my setup, the integration including the controls is very helpful and improves the comfort of my CTA head pump significantly. I can share the setup and code snippets if someone should be interested.
