If your boiler has modbus rtu interface, you use rs485-ttl converter and esphome board. For tcp skip esphome.
I have looked for sample ESPHome yaml for the KWB, but can’t find anything - I have copied the settings from other TCP modbus integrations but get no responses - my yaml is:
uart:
tx_pin: GPIO16
rx_pin: GPIO17
baud_rate: 9600
data_bits: 8
parity: NONE
stop_bits: 1
modbus:
uart_id: modbus_uart
modbus_controller:
modbus_id: modbus_client
address: 0x1
update_interval: 60s
- platform: modbus_controller
modbus_controller_id: modbus_device
# # Betriebsstunden
# # 0x982
address: 2337
unit_of_measurement: "h"
state_class: measurement
value_type: U_WORD
register_type: read
I get a log message of no repsonse. As I have added the RS485TTL via a cable onto the 2nd modbus connector on the board (and a 121ohm resistor). I don’t know if I need to register this with the KWB system as an extra peripheral, or whether I just need a different controller address?
Since your problem is not related to original post, I suggest you to open your own topic and post detailed description of your hardware (like rs485 converter) and your wiring. Also KWB model and modbus protocol sheet if you have.
Does this help?
Warning, most of MODBUS systems won’t answer if you don’t send a properly formatted message and that interrogates on a proper Modbus address so can be quite difficult to debug at begin…
[esphome Modbus TCP]
(GitHub - creepystefan/esphome_modbus_tcp: Modbus TCP for esphome · GitHub)
it work perfect
It’s possible you’d be interested in my uart link components. just simple components to create uart devices from tcp clients or servers and bridge them together - either with physical serial ports or other network “uarts”.
