Modifcations to Emulated Hue
Hi All,
It was annoying me my colour-temp lightbulbs weren’t working properly on my Echo (and all my lights showed up as colour changing - when none are) so I modified my emulated_hue component to better reflect a light’s capabilities
  1. Brightness now “optional” to support my on-off relay
  2. Hue/Sat only in state when bulb supports colour
  3. CT added to state for bulbs that support colour temp
  4. success response uses entity_number rather than id to match the api spec (don’t think this has achieved anything useful though)
so far controlling lights all works - including colour temp. there are still a couple of niggles:
  1. Lights regularly complain “Doesn’t support requested value” in the Alexa app
  2. The on/off only relay moans it’s unresponsive in the Alexa app - despite successfully toggling.
also I’ve not checked control from an Alexa yet (sleeping wife next to my Echo!) - although apart from probably getting some jip from her regarding the “unresponsive” relay, I can’t see why voice wouldn’t work.
This code is based off of my current HA install (version 0.94.3)
Apologies for posting here as oppose to using github; I’ve never used git in anger, so not even sure where to start getting this into the repository - but still want to share my work with community.
"""Support for a Hue API to control Home Assistant."""
import logging
from aiohttp import web
from homeassistant import core
from homeassistant.components import (
    climate, cover, fan, light, media_player, scene, script)
from homeassistant.components.climate.const import (
    SERVICE_SET_TEMPERATURE, SUPPORT_TARGET_TEMPERATURE)
from homeassistant.components.cover import (
    ATTR_CURRENT_POSITION, ATTR_POSITION, SERVICE_SET_COVER_POSITION,
    SUPPORT_SET_POSITION)
from homeassistant.components.fan import (
    ATTR_SPEED, SPEED_HIGH, SPEED_LOW, SPEED_MEDIUM, SPEED_OFF,
    SUPPORT_SET_SPEED)
from homeassistant.components.http import HomeAssistantView
from homeassistant.components.http.const import KEY_REAL_IP
from homeassistant.components.light import (
    ATTR_BRIGHTNESS, ATTR_HS_COLOR, SUPPORT_BRIGHTNESS, SUPPORT_COLOR, ATTR_COLOR_TEMP, SUPPORT_COLOR_TEMP)
from homeassistant.components.media_player.const import (
    ATTR_MEDIA_VOLUME_LEVEL, SUPPORT_VOLUME_SET)
from homeassistant.const import (
    ATTR_ENTITY_ID, ATTR_SUPPORTED_FEATURES, ATTR_TEMPERATURE,
    HTTP_BAD_REQUEST, HTTP_NOT_FOUND, SERVICE_CLOSE_COVER, SERVICE_OPEN_COVER,
    SERVICE_TURN_OFF, SERVICE_TURN_ON, SERVICE_VOLUME_SET, STATE_OFF, STATE_ON)
from homeassistant.util.network import is_local
_LOGGER = logging.getLogger(__name__)
HUE_API_STATE_ON = 'on'
HUE_API_STATE_BRI = 'bri'
HUE_API_STATE_HUE = 'hue'
HUE_API_STATE_SAT = 'sat'
HUE_API_STATE_TEMP = 'ct'
HUE_API_STATE_HUE_MAX = 65535.0
HUE_API_STATE_SAT_MAX = 254.0
HUE_API_STATE_BRI_MAX = 255.0
HUE_API_STATE_TEMP_MIN = 153
HUE_API_STATE_TEMP_MAX = 500
STATE_BRIGHTNESS = HUE_API_STATE_BRI
STATE_HUE = HUE_API_STATE_HUE
STATE_SATURATION = HUE_API_STATE_SAT
STATE_TEMP = HUE_API_STATE_TEMP
class HueUsernameView(HomeAssistantView):
    """Handle requests to create a username for the emulated hue bridge."""
    url = '/api'
    name = 'emulated_hue:api:create_username'
    extra_urls = ['/api/']
    requires_auth = False
    async def post(self, request):
        """Handle a POST request."""
        try:
            data = await request.json()
        except ValueError:
            return self.json_message('Invalid JSON', HTTP_BAD_REQUEST)
        if 'devicetype' not in data:
            return self.json_message('devicetype not specified',
                                     HTTP_BAD_REQUEST)
        if not is_local(request[KEY_REAL_IP]):
            return self.json_message('only local IPs allowed',
                                     HTTP_BAD_REQUEST)
        return self.json([{'success': {'username': '12345678901234567890'}}])
class HueAllGroupsStateView(HomeAssistantView):
    """Group handler."""
    url = '/api/{username}/groups'
    name = 'emulated_hue:all_groups:state'
    def __init__(self, config):
        """Initialize the instance of the view."""
        self.config = config
    @core.callback
    def get(self, request, username):
        """Process a request to make the Brilliant Lightpad work."""
                                     HTTP_BAD_REQUEST)
        return self.json({
class HueGroupView(HomeAssistantView):
    """Group handler to get Logitech Pop working."""
    url = '/api/{username}/groups/0/action'
    name = 'emulated_hue:groups:state'
    @core.callback
    def put(self, request, username):
        """Process a request to make the Logitech Pop working."""
                                     HTTP_BAD_REQUEST)
        return self.json([{
            'error': {
                'address': '/groups/0/action/scene',
                'type': 7,
                'description': 'invalid value, dummy for parameter, scene'
class HueAllLightsStateView(HomeAssistantView):
    """Handle requests for getting and setting info about entities."""
    url = '/api/{username}/lights'
    name = 'emulated_hue:lights:state'
    @core.callback
        """Process a request to get the list of available lights."""
                                     HTTP_BAD_REQUEST)
        hass = request.app['hass']
        json_response = {}
        for entity in hass.states.async_all():
            if self.config.is_entity_exposed(entity):
                state = get_entity_state(self.config, entity)
                number = self.config.entity_id_to_number(entity.entity_id)
                json_response[number] = entity_to_json(self.config,
                                                       entity, state)
        return self.json(json_response)
class HueOneLightStateView(HomeAssistantView):
    url = '/api/{username}/lights/{entity_id}'
    name = 'emulated_hue:light:state'
    @core.callback
    def get(self, request, username, entity_id):
        """Process a request to get the state of an individual light."""
                                     HTTP_BAD_REQUEST)
        entity_id = self.config.number_to_entity_id(entity_id)
        entity = hass.states.get(entity_id)
        if entity is None:
            _LOGGER.error('Entity not found: %s', entity_id)
            return web.Response(text="Entity not found", status=404)
        if not self.config.is_entity_exposed(entity):
            _LOGGER.error('Entity not exposed: %s', entity_id)
            return web.Response(text="Entity not exposed", status=404)
        json_response = entity_to_json(self.config, entity, state)
class HueOneLightChangeView(HomeAssistantView):
    url = '/api/{username}/lights/{entity_number}/state'
    async def put(self, request, username, entity_number):
        """Process a request to set the state of an individual light."""
                                     HTTP_BAD_REQUEST)
        config = self.config
        entity_id = config.number_to_entity_id(entity_number)
        if entity_id is None:
            _LOGGER.error('Unknown entity number: %s', entity_number)
            return self.json_message('Entity not found', HTTP_NOT_FOUND)
        if entity is None:
        if not config.is_entity_exposed(entity):
        try:
            request_json = await request.json()
        except ValueError:
            _LOGGER.error('Received invalid json')
        # Parse the request into requested "on" status and brightness
        parsed = parse_hue_api_put_light_body(request_json, entity)
        if parsed is None:
            _LOGGER.error('Unable to parse data: %s', request_json)
            return web.Response(text="Bad request", status=400)
        # Choose general HA domain
        domain = core.DOMAIN
        # Entity needs separate call to turn on
        turn_on_needed = False
        # Convert the resulting "on" status into the service we need to call
        service = SERVICE_TURN_ON if parsed[STATE_ON] else SERVICE_TURN_OFF
        # Construct what we need to send to the service
        data = {ATTR_ENTITY_ID: entity_id}
        # Make sure the entity actually supports brightness
        entity_features = entity.attributes.get(ATTR_SUPPORTED_FEATURES, 0)
        if entity.domain == light.DOMAIN:
            if parsed[STATE_ON]:
                if entity_features & SUPPORT_BRIGHTNESS:
                    if parsed[STATE_BRIGHTNESS] is not None:
                        data[ATTR_BRIGHTNESS] = parsed[STATE_BRIGHTNESS]
                if entity_features & SUPPORT_COLOR_TEMP:
                    if parsed[STATE_TEMP] is not None:
                        data[ATTR_COLOR_TEMP] = parsed[STATE_TEMP]
                if entity_features & SUPPORT_COLOR:
                    if parsed[STATE_HUE] is not None:
                        if parsed[STATE_SATURATION]:
                            sat = parsed[STATE_SATURATION]
                        else:
                            sat = 0
                        hue = parsed[STATE_HUE]
                        # Convert hs values to hass hs values
                        sat = int((sat / HUE_API_STATE_SAT_MAX) * 100)
                        hue = int((hue / HUE_API_STATE_HUE_MAX) * 360)
                        data[ATTR_HS_COLOR] = (hue, sat)
        # If the requested entity is a script add some variables
        elif entity.domain == script.DOMAIN:
            data['variables'] = {
                'requested_state': STATE_ON if parsed[STATE_ON] else STATE_OFF
                data['variables']['requested_level'] = parsed[STATE_BRIGHTNESS]
        # If the requested entity is a climate, set the temperature
        elif entity.domain == climate.DOMAIN:
            # We don't support turning climate devices on or off,
            # only setting the temperature
            service = None
            if entity_features & SUPPORT_TARGET_TEMPERATURE:
                    domain = entity.domain
                    service = SERVICE_SET_TEMPERATURE
                    data[ATTR_TEMPERATURE] = parsed[STATE_BRIGHTNESS]
        # If the requested entity is a media player, convert to volume
        elif entity.domain == media_player.DOMAIN:
            if entity_features & SUPPORT_VOLUME_SET:
                    turn_on_needed = True
                    service = SERVICE_VOLUME_SET
                    # Convert 0-100 to 0.0-1.0
                    data[ATTR_MEDIA_VOLUME_LEVEL] = \
                        parsed[STATE_BRIGHTNESS] / 100.0
        # If the requested entity is a cover, convert to open_cover/close_cover
        elif entity.domain == cover.DOMAIN:
            if service == SERVICE_TURN_ON:
                service = SERVICE_OPEN_COVER
            else:
                service = SERVICE_CLOSE_COVER
            if entity_features & SUPPORT_SET_POSITION:
                    service = SERVICE_SET_COVER_POSITION
                    data[ATTR_POSITION] = parsed[STATE_BRIGHTNESS]
        # If the requested entity is a fan, convert to speed
        elif entity.domain == fan.DOMAIN:
            if entity_features & SUPPORT_SET_SPEED:
                    # Convert 0-100 to a fan speed
                    brightness = parsed[STATE_BRIGHTNESS]
                    if brightness == 0:
                        data[ATTR_SPEED] = SPEED_OFF
                    elif 0 < brightness <= 33.3:
                        data[ATTR_SPEED] = SPEED_LOW
                    elif 33.3 < brightness <= 66.6:
                        data[ATTR_SPEED] = SPEED_MEDIUM
                    elif 66.6 < brightness <= 100:
                        data[ATTR_SPEED] = SPEED_HIGH
        if entity.domain in config.off_maps_to_on_domains:
            # Map the off command to on
            # Caching is required because things like scripts and scenes won't
            # report as "off" to Alexa if an "off" command is received, because
            # they'll map to "on". Thus, instead of reporting its actual
            # status, we report what Alexa will want to see, which is the same
            # as the actual requested command.
            config.cached_states[entity_id] = parsed
        # Separate call to turn on needed
        if turn_on_needed:
            hass.async_create_task(hass.services.async_call(
                core.DOMAIN, SERVICE_TURN_ON, {ATTR_ENTITY_ID: entity_id},
                blocking=True))
        if service is not None:
                domain, service, data, blocking=True))
        json_response = \
            [create_hue_success_response(
                entity_number, HUE_API_STATE_ON, parsed[STATE_ON])]
            json_response.append(create_hue_success_response(
                entity_number, HUE_API_STATE_BRI, parsed[STATE_BRIGHTNESS]))
                entity_number, HUE_API_STATE_TEMP, parsed[STATE_TEMP]))
                entity_number, HUE_API_STATE_HUE, parsed[STATE_HUE]))
        if parsed[STATE_SATURATION] is not None:
                entity_number, HUE_API_STATE_SAT, parsed[STATE_SATURATION]))
def parse_hue_api_put_light_body(request_json, entity):
    """Parse the body of a request to change the state of a light."""
    data = {
        STATE_BRIGHTNESS: None,
        STATE_HUE: None,
        STATE_ON: False,
        STATE_SATURATION: None,
        STATE_TEMP: None
    if HUE_API_STATE_ON in request_json:
        if not isinstance(request_json[HUE_API_STATE_ON], bool):
            return None
        if request_json[HUE_API_STATE_ON]:
            # Echo requested device be turned on
            data[STATE_BRIGHTNESS] = None
            data[STATE_ON] = True
        else:
            # Echo requested device be turned off
            data[STATE_ON] = False
    else:
        data[STATE_ON] = entity.state != STATE_OFF
    if HUE_API_STATE_HUE in request_json:
        try:
            # Clamp brightness from 0 to 65535
            data[STATE_HUE] = \
                max(0, min(int(request_json[HUE_API_STATE_HUE]),
                           HUE_API_STATE_HUE_MAX))
        except ValueError:
            return None
    if HUE_API_STATE_SAT in request_json:
        try:
            # Clamp saturation from 0 to 254
            data[STATE_SATURATION] = \
                max(0, min(int(request_json[HUE_API_STATE_SAT]),
                           HUE_API_STATE_SAT_MAX))
        except ValueError:
            return None
    if HUE_API_STATE_TEMP in request_json:
        try:
            #direct setting
            data[STATE_TEMP] = request_json[HUE_API_STATE_TEMP]
        except ValueError:
            return None
    if HUE_API_STATE_BRI in request_json:
        try:
            # Clamp brightness from 0 to 255
            data[STATE_BRIGHTNESS] = \
                max(0, min(int(request_json[HUE_API_STATE_BRI]),
                           HUE_API_STATE_BRI_MAX))
        except ValueError:
            return None
            data[STATE_ON] = (data[STATE_BRIGHTNESS] > 0)
            if not entity_features & SUPPORT_BRIGHTNESS:
        elif entity.domain == scene.DOMAIN:
        elif entity.domain in [
                script.DOMAIN, media_player.DOMAIN,
                fan.DOMAIN, cover.DOMAIN, climate.DOMAIN]:
            # Convert 0-255 to 0-100
            level = (data[STATE_BRIGHTNESS] / HUE_API_STATE_BRI_MAX) * 100
            data[STATE_BRIGHTNESS] = round(level)
    return data
def get_entity_state(config, entity):
    """Retrieve and convert state and brightness values for an entity."""
    cached_state = config.cached_states.get(entity.entity_id, None)
    data = {
        STATE_HUE: None,
        STATE_ON: False,
        STATE_TEMP: None
    if cached_state is None:
#        if data[STATE_ON]:
#            data[STATE_BRIGHTNESS] = entity.attributes.get(ATTR_BRIGHTNESS, 0)
#            hue_sat = entity.attributes.get(ATTR_HS_COLOR, None)
#            if hue_sat is not None:
#                hue = hue_sat[0]
#                sat = hue_sat[1]
#                # convert hass hs values back to hue hs values
#                data[STATE_HUE] = int((hue / 360.0) * HUE_API_STATE_HUE_MAX)
#                data[STATE_SATURATION] = \
#                    int((sat / 100.0) * HUE_API_STATE_SAT_MAX)
#        else:
#            data[STATE_BRIGHTNESS] = 0
#            data[STATE_HUE] = 0
#            data[STATE_SATURATION] = 0
                data[STATE_TEMP] = entity.attributes.get(ATTR_COLOR_TEMP,HUE_API_STATE_TEMP_MIN)
                    hue = hue_sat[0]
                    sat = hue_sat[1]
            temperature = entity.attributes.get(ATTR_TEMPERATURE, 0)
            # Convert 0-100 to 0-255
            data[STATE_BRIGHTNESS] = round(temperature * 255 / 100)
            level = entity.attributes.get(
                ATTR_MEDIA_VOLUME_LEVEL, 1.0 if data[STATE_ON] else 0.0)
            # Convert 0.0-1.0 to 0-255
                round(min(1.0, level) * HUE_API_STATE_BRI_MAX)
            speed = entity.attributes.get(ATTR_SPEED, 0)
            if speed == SPEED_LOW:
                data[STATE_BRIGHTNESS] = 85
            elif speed == SPEED_MEDIUM:
                data[STATE_BRIGHTNESS] = 170
            elif speed == SPEED_HIGH:
                data[STATE_BRIGHTNESS] = 255
            level = entity.attributes.get(ATTR_CURRENT_POSITION, 0)
            data[STATE_BRIGHTNESS] = round(level / 100 * HUE_API_STATE_BRI_MAX)
    else:
        data = cached_state
            # Make sure brightness is valid
                if data[STATE_BRIGHTNESS] is None:
                    data[STATE_BRIGHTNESS] = 255 if data[STATE_ON] else 0
                # Make sure ctemp is valid
                if data[STATE_TEMP] is None:
                    data[STATE_TEMP] = HUE_API_STATE_TEMP_MIN
                # Make sure hue/saturation are valid
                if (data[STATE_HUE] is None) or (data[STATE_SATURATION] is None):
                    data[STATE_HUE] = 0
                # If the light is off, set the color to off
                if data[STATE_BRIGHTNESS] == 0:
                    data[STATE_HUE] = 0
        else:
                data[STATE_HUE] = 0
                data[STATE_HUE] = 0
    return data
def entity_to_json(config, entity, state):
    """Convert an entity to its Hue bridge JSON representation."""
    retval = {
        'state':
            HUE_API_STATE_ON: state[STATE_ON],
            'reachable': True
        'type': 'Dimmable light',
        'name': config.get_entity_name(entity),
        'modelid': 'HASS123',
        'uniqueid': entity.entity_id,
        'swversion': '123'
    if state[STATE_BRIGHTNESS] is not None:
        retval['state'][HUE_API_STATE_BRI] = state[STATE_BRIGHTNESS]
    if state[STATE_HUE] is not None:
        retval['state'][HUE_API_STATE_HUE] = state[STATE_HUE]
    if state[STATE_SATURATION] is not None:
        retval['state'][HUE_API_STATE_SAT] = state[STATE_SATURATION]
    if state[STATE_TEMP] is not None:
        retval['state'][HUE_API_STATE_TEMP] = state[STATE_TEMP]
    return retval
def create_hue_success_response(entity_number, attr, value):
    """Create a success response for an attribute set on a light."""
    success_key = '/lights/{}/state/{}'.format(entity_number, attr)
    return {'success': {success_key: value}}
