Modify/delete legacy schedules in Insteon Hub?
I’m new to the Home Assistant community due to the shuttering of Insteon. I’m up and running with a Raspberry Pi, but have some legacy schedules in the Insteon hub for some of my lights. Is there a way to delete those schedules so that I can recreate and edit them in Home Assistant? My assumption is that I cannot edit the schedules that are in the Insteon Hub any longer so I would like to delete them and recreate them in Home Assistant so that I will be able to edit as needed in the future. Thanks.
Toward the bottom of this post on Reddit, someone mentioned Insteon Terminal (which I think is just for Linux):
I also saw someone mention elsewhere that a factory reset and then relinking your devices would work, but that seems risky.
I am hoping someone will try one of these and give us some more details.
