Modify sun elevation threshold with input number variable
Is it possible to create an automation using sun.sun elevation and use an input_number to set the above/below parameter?
In able to do it with timers to set duration, but I can’t seem to figure this one out…
Yes, see the fourth example here:
https://www.home-assistant.io/docs/automation/trigger/#numeric-state-trigger
