Modify trigger time with input_number
Hi there.
I’m trying to modify the Trigger value (Time) of an automation, from an Input-number in the front end.
Example:
Th input number goes like:
input_number:
  start_time:
    initial: 4
    min: 0
    max: 23
    step: 1
And the automation is:
  - at: '{{ states.input_number.start_time.state | int }}:00:00'
    platform: time
  condition: []
  - data:
      entity_id: switch.plug_151515151515
    service: switch.turn_on
But this trigger returns me an error. I just want to modify the hours, not the minutes or seconds.
Someone knows how i can get this working?
Thanks!
Well, this has been answered many times on this forum. The docs should probably be updated to add an example of how to do this. :slight_smile:
Anyway, the time trigger’s at parameter does not accept a template. So you should enable the Time sensor:
  - platform: time_date
    display_options:
      - 'time'
Then use a template trigger:
  platform: template
  value_template: >
    {{ states('sensor.time').split(':')[0]|int ==
       states('input_number.start_time')|int }}
It’s funny that you say this. The docs do have it for a input_datetime, just not an input_number.
