Hello there, anyone tried the Moes 10.1" screen with HA?
I´m looking for a in-wall mounted screen 10" and up and this seems interesting, but don´t know if i can display a dashboard from HA.
#1 - It’s Tuya
#2 - Even if it is, $569 is a non-starter for what an Amazon Fire Tablet for $100 already does.
#3 - It’s Tuya.
It´s half the price in Aliexpress, but not very cheap yet.
I was looking for an in-wall screen, it´s easy for me power it with 230V.
Could try one of this.
I have no clue what the photo you posted is of, but it looks like an ON-wall charger. What? You glue magnets to the back of a tablet?
That´s it, i can´t see specs…
https://www.aliexpress.com/item/1005007488938077.html
This is way off-topic from the $569 in-wall Tuya panel.
The Ali Express product is a magnet base glued to your tablet, any tablet. Then you wire the base to your line power.
If you don’t mind your tablet sticking out from the wall almost one-inch, then this might be a good solution. I would even consider it if I had a tablet that would run Fully Kiosk.
Note, the USB power cable on the side of the tablet.
Yes, but they don´t mention any specs about the charger, don´t know if it´s garbage or not…
There are no specs other than “5V, 2A with no heating”. Not confidence inspiring. There is also no indication if the charging power throttles down when the battery is full. If it doesn’t then you would shorten the life of the tablet battery. You could optionally remove the table battery and just run it off the charger.
Thanks, I think that would be better install a wall mounted USB Zigbee plug and program its on and off according to the battery state.
In this case i’ll have to install a tablet mount behind the plug. I’ll search a good universal one.
