Hello everyone!
I am new for Home Assistant and will be very glad to get some help here
I have Zigbee remote with 4 button Moes Tuya Smart ZigBee Point to Point Control Scene Switch 4 Gang Portable – MOES and trying put it into my Home Assistant environment. I used official integration for Tuya via Tuya IoT Hub and it works good for all other my Zigbee devices. For Zigbee hub I used Tervix WiFi hub.
My remote appears in Home Assistant but without any buttons, and I can’t create an automation for it. Here is a config file for my device:
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2023.5.2",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.11",
"docker": true,
"arch": "aarch64",
"timezone": "Europe/Kyiv",
"os_name": "Linux",
"os_version": "6.1.21-v8",
"supervisor": "2023.04.1",
"host_os": "Home Assistant OS 10.1",
"docker_version": "23.0.3",
"chassis": "embedded",
"run_as_root": true
"custom_components": {
"ariston": {
"version": "0.13.1",
"requirements": [
"ariston==0.13.1"
"miwifi": {
"version": "3.0.0",
"requirements": []
"hacs": {
"version": "1.32.1",
"requirements": [
"aiogithubapi>=22.10.1"
"integration_manifest": {
"domain": "tuya",
"name": "Tuya",
"codeowners": [
"@Tuya",
"@zlinoliver",
"@frenck"
"config_flow": true,
"dependencies": [
"ffmpeg"
"dhcp": [
"macaddress": "105A17*"
"macaddress": "10D561*"
"macaddress": "1869D8*"
"macaddress": "381F8D*"
"macaddress": "508A06*"
"macaddress": "68572D*"
"macaddress": "708976*"
"macaddress": "7CF666*"
"macaddress": "84E342*"
"macaddress": "D4A651*"
"macaddress": "D81F12*"
"documentation": "https://www.home-assistant.io/integrations/tuya",
"integration_type": "hub",
"iot_class": "cloud_push",
"loggers": [
"tuya_iot"
"requirements": [
"tuya-iot-py-sdk==0.6.6"
"is_built_in": true
"data": {
"endpoint": "https://openapi.tuyaeu.com",
"auth_type": 0,
"country_code": "380",
"app_type": "smartlife",
"mqtt_connected": true,
"disabled_by": null,
"disabled_polling": false,
"name": "Remote",
"model": "",
"category": "wxkg",
"product_id": "abci1hiu",
"product_name": "4 Gang ZigBee Scene Remote",
"online": true,
"sub": true,
"time_zone": "+03:00",
"active_time": "2023-05-07T15:43:28+00:00",
"create_time": "2023-05-07T14:53:33+00:00",
"update_time": "2023-05-07T15:43:28+00:00",
"function": {},
"status_range": {
"switch1_value": {
"type": "Enum",
"value": {
"range": [
"single_click",
"double_click",
"long_press"
"switch_mode2": {
"type": "Enum",
"value": {
"range": [
"click",
"double_click",
"press"
"switch_mode3": {
"type": "Enum",
"value": {
"range": [
"click",
"double_click",
"press"
"switch_mode4": {
"type": "Enum",
"value": {
"range": [
"click",
"double_click",
"press"
"battery_percentage": {
"type": "Integer",
"value": {
"unit": "%",
"min": 0,
"max": 100,
"scale": 0,
"step": 1
"status": {
"switch1_value": "double_click",
"switch_mode2": "click",
"switch_mode3": "double_click",
"switch_mode4": "click"
"home_assistant": {
"name": "Remote",
"name_by_user": null,
"disabled": false,
"entities": []
Does anybody had this problem? Maybe some potential fixes can be made? Looks like state is updating as well, but I am new to Automation and don’t know how to try bind on it. I will be glad to get any kind of help! Thank you very much for read this topic. Hope somebody will answer
