MOES ZigBee Star Ring Smart Thermostat
Good Morning
I don’t find many reviews online about Moes
ZigBee Star Ring Smart Thermostat. Do you recommend it? Anyone using it in home assistant with zigbee 2 mqtt without any moes hub?
Models are: ZHT-SR-GA-WH-MS or ZHT-SR-GC-WH-MS or ZHT-SR-GB-WH-MS
Hi giovanniong,
I am using the GB version for about 2 weeks now, without a Hub (with Z2M) and it works well. The only thing (I didn’t find out yet) which is not shown correctly is the day (I assume its because the date is not set).
I tried to change the date within HA, but I could not find a way yet.
I assume the date is set automatically, when its connected to the Moes Hub.
But if this is ok for you, then it might be a good choice.
BR Chg0815
Hi Giovanniong,
I know this post is a bit old, but I hope it helps others who are looking for information.
I’ve been using the thermostat for a few days now, and my conclusion is: you get what you pay for.
It looks decent at first glance, but once you start using it, it feels a little cheap, but not too bad. As ChG0815 mentioned, there’s no way to set the day of the week. Honestly, the text for the day is so small that it makes no real difference.
I’m using it through Z2M, and it works. However, there’s no way to set schedules or use external temperature sensors directly through the unit or Z2M—but you can achieve similar functionality via Home Assistant.
One thing I really dislike is the offset precision—it only allows adjustments in 1-degree increments. Additionally, the temperature reported by the unit can be off by up to 2 degrees. I managed to work around this by using other thermometers I have to dynamically adjust the offset, which keeps the thermostat within 0.5 degrees of the actual temperature.
With that said, with a bit (in my case, a lot) of effort, you can make it work—but it definitely requires some tweaking. I don’t regret buying it, but I wouldn’t recommend it unless you’re willing to spend time fiddling with Home Assistant to improve its accuracy.
Lastly, I bought it in the UK and it came set to Celsius. There’s no way to change the temperature unit to Fahrenheit through Z2M or via the unit’s interface.
Hi, coming back to your post, because you seem to have managed to get it to work with an external sensor in HA. I am trying to achieve this via a yaml-automation, but it does not seem to work. The running_state does not change, although hvac_mode = heating.
Do you have a suggestion or a blueprint?
you can use better thermostat for that
GitHub - KartoffelToby/better_thermostat: This custom component for Home Assistant will add crucial features to your climate-controlling TRV (Thermostatic Radiator Valves) to save you the work of creating automations to make it smart. It combines a room-temperature sensor, window/door sensors, weather forecasts, or an ambient temperature probe to decide when it should call for heat and automatically calibrate your TRVs to fix the imprecise measurements taken in the radiator's vicinity.
Hi, I try to connect it to Deconz but i can’t get it in pairing mode. When I say yes to pairing mode I see a qr and than nothing happens. In the SmartLife app there is no zigbee controller because I’m using deconz in home assistant. Could you please help me with this?
I bought one and sent it back. The idea of a turning knob is nice because it’s “old school” and easy for everyone to use, the light around it looks great and the screen looks very good indeed BUT all of that is completely lost because the knob is not mounted firmly. It turns when you turn the knob (ring) so you see the screen move left and right a bit, and also it’s wiggly. This makes it feel cheap and not lasting. Because of this I returned it.
