MoesGo Devices
Hi All,
I have a few Moes go devices that work on zigbee.
Is there a way to make them work with with HA.
Im using HASS in a virtual machine on Windows with a Sonoff USB 3.0 Zigbee.
I haven’t heard of MoesGo, but if the same as Moes, some work.
Here is a good non-official link for looking at what works with ZHA. That same site let’s you look at ZigBee2mqtt, if you’re using that.
https://zigbee.blakadder.com/zha.html
Yes it’s Moes. Apologies.
But I’m confused. I’ve paid one Moes remote. However it doesn’t seem to function correctly.
How do I configure it?
Which device precisely. What errors? What logs?
Read these two sections in ZHA docs:
Summery; try joining/pairing the the device in ZHA and if it is not fully working then post a new devices support request issue with the device signature to → https://github.com/zigpy/zha-device-handlers/issues
Thanks all.
I deleted the devices and re added them after seeing they were on the compatible list.
Seem to be working fine now
@liamb FYI, joining/pairing and device interrogation can partially fail due to interference or bad reception so be sure to read and follow → https://github.com/zigpy/zigpy/wiki/Generic-best-practice-tips-on-improving-Zigbee-network-range-and-general-stability
