Full logs
2022-09-22 07:22:08.463 ERROR (MainThread) [homeassistant.components.mold_indicator.sensor] Temp sensor sensor.davis_vantage_pro_humidity_outside has unsupported unit: % (allowed: °C, °F)
2022-09-22 07:22:08.473 ERROR (MainThread) [homeassistant.components.mold_indicator.sensor] Temp sensor sensor.davis_vantage_pro_humidity_outside has unsupported unit: % (allowed: °C, °F)
2022-09-22 07:22:08.474 ERROR (MainThread) [homeassistant.components.mold_indicator.sensor] Temp sensor sensor.davis_vantage_pro_humidity_outside has unsupported unit: % (allowed: °C, °F)
The configuration is per the documentation. Thinking that adding unit_of_measurement: °F would sort that error generates this set of errors when checking configuration validation:
```Configuration invalid!
Invalid config for [sensor.mold_indicator]: [unit_of_measurement] is an invalid option for [sensor.mold_indicator]. Check: sensor.mold_indicator->unit_of_measurement. (See ?, line ?). Invalid config for [sensor.mold_indicator]: [unit_of_measurement] is an invalid option for [sensor.mold_indicator]. Check: sensor.mold_indicator->unit_of_measurement. (See ?, line ?). Invalid config for [sensor.mold_indicator]: [unit_of_measurement] is an invalid option for [sensor.mold_indicator]. Check: sensor.mold_indicator->unit_of_measurement. (See ?, line ?).```
Doh! Outside humidity vice outside air temp!
