Momentary button functionality
I believe it would be very useful if the base climate integration had support for momentary button commands.
This would be functions that do not trigger a continuous state, for example, my AC unit has a button to set the swing mode (Vertical/Horizontal/Both/None) which is supported by the current integration. However, the remote has another function to adjust the swing by a single step which does not fit in with the current integration.
