Momentary off state when reloading MQTT entities
I’m having an issue when reloading manually configured MQTT entities that is, if an entity was previously on, it will go from onunavailable (expected during the reload) → off (for less than a second) → on (state before the reload).
This is causing me an issue since I have automations that trigger based on the transition from off to on of these entities and the reload always trigger those automations.
This happens both with Shelly with stock firmware as well as some led strips flashed with Tasmota.
Example:
I have an automation that triggers on restarts and reloads that forces Shellies and Tasmotas to publish their current state:
- id: 'mqtt_discovery'
  alias: 'MQTT Discovery'
    - platform: homeassistant
      event: start
    - platform: event
      event_type: event_mqtt_reloaded
    - platform: time
      at: '21:00:00'
    - service: mqtt.publish
      data: # Shellies Publish State
        topic: 'shellies/command'
        payload: 'update'
      data: # Shellies Publish Attributes
        payload: 'announce'
      data: # Tasmotas Publish State
        topic: 'cmnd/tasmotas/POWER0'
      data: # Tasmotas Publish Attributes
        topic: 'cmnd/tasmotas/STATUS0'
I’ve also confirmed manually via mosquitto_sub that I’m not receiving any off message on the entity topic, so this must be Home Assistant that is assuming this off state.
