That should be an easy task for this project. LEt me know if you want me to help you remotely. DOnt worry I wouldnt charge you or anything. What you could try is hcitool name 00:00:00:00:00:00
This will show you if the name scans are working properly.
thanks… I wasn’t saying you would and I do appreciate it!
yep name scans work perfectly and arrival scans also work via the schedule in the preference setting. Just need to find out how to trigger them so I know monitor detect our phone as we get close to the house. BT is detected well into the street.
if you are using Monitor.sh -trd -x this will trigger on bluetooth advertisement AND trigger with a message sent to the MQTT server $mqtt_topicpath/scan/DEPART
if your name scans are working properly then there really should be an issue unless your phone doesnt follow the BLE spec which would be something before 2011 i think
yeah this is exactly what I am running at the moment. just tested sat here… BT off , manually sent the depart message via HA, count down to 0 - perfect.
wait 10 minutes, turn BT back on…5 minutes later, so no arrive ran. It is a 2018 Huawei mate 10 pro phone.
Try running a test to make sure that you phone actually broadcasts random advertisements.
In one ssh session, run the command sudo hcitool lescan while you run in another session sudo hcidump -a. Wait for a moment for the second command to settle down. Then, watch the output when you toggle Bluetooth on and off on your phone.
You should see a “new” device show up every time you toggle. It’ll appear as a random advertisement.
I can confirm that on the beta branch and version 0.1.707 my Nut 3 Mini is now detected correctly with mac address in uppercase in known_static_addresses and with the -g flag.
Now the only undetected device I have is an Apple Watch 4 - anyone successfully detected one of those?
git fetch git://github.com/andrewjfreyer/monitor/tree/beta
fatal: remote error:
andrewjfreyer/monitor/tree/beta is not a valid repository name
Email [email protected] for help
I’ve now upgraded to 0.1.675
but publishing to monitor/scan/UPDATEBETA doesn’t do anything monitor just repeats the mqtt message back to me
EDIT: ok thanks guys got it to work now, I was using an old version of my mqtt pref file from when I was using presence )
EDIT 2: my nut mini still comes up with confidence 0
Does anybody schedule a reboot of their nodes? I have an issue that on occasion they can become unresponsive. I might add a cron job but wasn’t sure if their was a better way.
this is what I do. (modified from earlier)
When my door opens I tell it to cancel mqtt_depart script just in case is still running from the last time someone closed the door. Once the door closes this depart script runs. On the last line it restarts the service.
Restarting of the service seems to have kept mine up and running.
If you really want an actual Reboot im sure @andrewjfreyer could easily add this OR you could modify Line 731 of Monitor.sh. (assuming you are on 0.1.675)
I have the exact same implementation (created from hints in your previous comments, thanks again). Whats the longest you’ve been up and running without requiring a reboot? Since leaving them alone I estimate mine lock up around once a week. Being able to issue a reboot this way will allow me to add some logic to when it takes place.
As if you haven’t already done enough would you mind adding this @andrewjfreyer ? If its added your end I can keep on pulling future changes.
