Monitoring a large number of thermostatic valves for a specific condition
I have 15 tuya thermostatic radiator valves, which are currently being controlled by homeassistant. Unfortunately they have a tendency to overshoot the target temperature, and it was reasonably straightforward to write a script that can monitor a single valve and turn if off and then back on in 30 secs (which closes the valve), if the target temperature is reached and the valve is open.
However, I would like to come up with a general solution that can monitor all 15 valves. From my reading of the automations it doesn’t seem like there is an easy way to have a single automation monitor all 15 valves separately, so I have been working on a script to loop through all the valves evaluating each one in turn, with the idea that I could run it every 5 minute and catch the valves that are overshooting. This seems less elegant, but should work, although I am having trouble getting my script to work correctly.
The script I have been trying to work on is below. The overall idea is it loops through all the valves in the group all_valves, and evaluates whether the current_temperature is greater than the (target) temperature, and if the valve is open, though I am having trouble getting the state_attr templates to evaluate correctly when using the variables I have defined - I am definitely a beginner and am probably making some sort of relatively elementary mistake with my value template.
alias: WIP Overshoot Monitor
sequence:
  - variables:
      entityids: '{{ expand(''group.all_valves'') | map(attribute=''entity_id'') | list }}'
  - repeat:
      count: '{{ entityids | count }}'
      sequence:
        - choose:
            - conditions:
                - condition: template
                  value_template: >-
                    state_attr('{{entityids[repeat.index-1]}}','current_temperature')|int
                    >=  state_attr('{{entityids[repeat.index-1]}}',
                    'temperature')|int  }}
                  value_template: >-
                    {{ state_attr('{{entityids[repeat.index-1]}}','position') |
                    int > 40 }}
              sequence:
                - service: script.wip_overshoot_valve_interrupt
                    data_template:
                      valvetointerrupt: >-
                        'friendly_name') }}
          default: []
mode: single
My questions for more advanced HA user are:
  1. Am I correct that there is not an easy way to do this with automations?
  2. If so, or I suppose in addition, could anyone give me insight as to why my script is failing?
Thanks for any thoughts or insight!
Ted
