Hi guys,
I started building some “WIFI sensor” using wemos D1 and some temperature sensor. The first one I built is for my pool temperature.
So, I built a “sensor box” with a db18b20 and a wemos d1. The program on the D1 take the tempeture and post it via MQTT each 5 minutes.
This part is good ans work great.
What I want to add is something to monitor that the “sensor box” is still working. A “non-working” box is one that didn’t update my MQTT sensor since more than 5 minutes.
I would like to use the Alert feature of HomeAssistant based and an input_boolean called “MQTT pool sensor alive”.
I then built 2 automation to make the input_boolean ON and OFF.
First automation trigger on
{{ as_timestamp(now()) - as_timestamp(states.sensor.pooltemperature.last_updated) | int > 300 }}`
and set my input_boolean to OFF.
Second automation trigger on
{{ as_timestamp(now()) - as_timestamp(states.sensor.pooltemperature.last_updated) | int < 301 }}
and set my input_boolean to ON
But my automation is not trigered and I don’t know why. Anyone has an idea ?
Is there a better way to do my sensor monitoring ?
