The new qt-openzwave integration lacks sensors to monitor the status of the daemon, obtain the version of the running daemon, and dead nodes can’t be detected. This can be fixed via some mqtt sensors.
- platform: mqtt
state_topic: "OpenZWave/1/status/"
value_template: "{{value_json.Status}}"
json_attributes_topic: "OpenZWave/1/status/"
- platform: mqtt
name: "Zwave Node Event"
state_topic: "OpenZWave/1/event/notification/"
value_template: "{{value_json.Event}}"
json_attributes_topic: "OpenZWave/1/event/notification/"
The Zwave Status sensor values are described here.
Some example automations for the sensor… One notifies upon daemon crash, the other restarts homeassistant when qt-openzwave daemon fully restarts.
automation:
- alias: 'Zwave Offline Notifier'
- platform: state
entity_id: sensor.zwave_status
to: 'Offline'
service: notify.text
data_template:
message: "Zwave Daemon is down!"
tag: 'zwavedown'
- alias: 'Zwave Reboot'
- platform: state
to: 'driverAllNodesQueried'
- service: notify.mobile_app_moto_g_5_plus
data_template:
message: "Zwave Daemon is up! Homeassistant will restart!"
tag: 'zwaveup'
- delay : 00:05:00
- service: homeassistant.restart
The Zwave Node Event sensor is going to generate lots of DB entries depending on the number of battery operated devices and how often they awake. It may be advisable to exclude it from history.
Here is an automation to notify upon the discovery of a dead node. (MQTT state and attributes cannot update within a sensor simultaneously so the automation only uses attribute data to avoid that race condition.)
automation:
- alias: Zwave Dead Node Notifier
value_template: "{{is_state_attr('sensor.zwave_node_event', 'Event', 'Notification_Code_NodeDead')}}"
- service: notify.email
data_template:
title: "Node {{states.sensor.zwave_node_event.attributes.Node}} is dead!"
message: "Please Check or Fix!"
