This flow creates a couple of sensors. One for today’s water volume, and another one to store yesterday’s total volume, this way you can track both. Your mqtt sensor reading should be set in msg.sum. Initialize the sensor one time to 0 and you can delete that inject node.
[{"id":"fed44578.0f9e68","type":"inject","z":"878e74c2.7f39c8","name":"sum +3","props":[{"p":"sum","v":"3","vt":"num"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":590,"y":3740,"wires":[["222686a8.76b59a"]]},{"id":"3374dc44.575504","type":"ha-entity","z":"878e74c2.7f39c8","name":"sensor.today_total_volume","server":"9405c3fe.d0a6c","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"today_total_volume"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":""}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":1360,"y":3740,"wires":[[]]},{"id":"193b6b9d.3a67a4","type":"inject","z":"878e74c2.7f39c8","name":"Initialize sensor to 0 just the first time, otherwise it won't work","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0","payloadType":"num","x":860,"y":3640,"wires":[["3374dc44.575504"]]},{"id":"70026ddd.2daf94","type":"inject","z":"878e74c2.7f39c8","name":"Store today's value to yesterday's value and reset to 0 every day at 00:00","props":[],"repeat":"","crontab":"00 00 * * *","once":false,"onceDelay":0.1,"topic":"","x":280,"y":3840,"wires":[["bd2662e8.4b4f"]]},{"id":"222686a8.76b59a","type":"api-current-state","z":"878e74c2.7f39c8","name":"Get current value","server":"9405c3fe.d0a6c","version":3,"outputs":1,"halt_if":"","halt_if_type":"num","halt_if_compare":"is","entity_id":"sensor.today_total_volume","state_type":"num","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":770,"y":3740,"wires":[["df4adcdc.a128"]]},{"id":"bd2662e8.4b4f","type":"api-current-state","z":"878e74c2.7f39c8","name":"Get current value","server":"9405c3fe.d0a6c","version":3,"outputs":1,"halt_if":"","halt_if_type":"num","halt_if_compare":"is","entity_id":"sensor.today_total_volume","state_type":"str","blockInputOverrides":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":650,"y":3840,"wires":[["64a4913d.6238a"]]},{"id":"64a4913d.6238a","type":"ha-entity","z":"878e74c2.7f39c8","name":"sensor.yesterday_total_volume","server":"9405c3fe.d0a6c","version":1,"debugenabled":false,"outputs":1,"entityType":"sensor","config":[{"property":"name","value":"yesterday_total_volume"},{"property":"device_class","value":""},{"property":"icon","value":""},{"property":"unit_of_measurement","value":""}],"state":"payload","stateType":"msg","attributes":[],"resend":true,"outputLocation":"","outputLocationType":"none","inputOverride":"allow","outputOnStateChange":false,"outputPayload":"$entity().state ? \"on\": \"off\"","outputPayloadType":"jsonata","x":890,"y":3840,"wires":[["c9878f25.c7819"]]},{"id":"ac49d137.269fd","type":"comment","z":"878e74c2.7f39c8","name":"Your mqtt sensor readings through here --- >>","info":"","x":330,"y":3740,"wires":[]},{"id":"c9878f25.c7819","type":"change","z":"878e74c2.7f39c8","name":"Reset today's sensor","rules":[{"t":"set","p":"payload","pt":"msg","to":"0","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":1140,"y":3840,"wires":[["3374dc44.575504"]]},{"id":"df4adcdc.a128","type":"change","z":"878e74c2.7f39c8","name":"payload to payload + sum","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload + sum","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":990,"y":3740,"wires":[["3374dc44.575504"]]},{"id":"e3ba48f0.d73a58","type":"comment","z":"878e74c2.7f39c8","name":"Today's total volume","info":"","x":1330,"y":3700,"wires":[]},{"id":"125a9e57.dce382","type":"comment","z":"878e74c2.7f39c8","name":"Yesterday's total volume","info":"","x":870,"y":3800,"wires":[]},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
