Monoprice 4-in-1 sensor and InfluxDb
does your hass populate the values in the influxDB for Z-wave sensor Monoprice 4-in-1 ?
I’ve got only below:
SELECT * FROM “autogen”.“sensor.vision_zp3111_multisensor_4in1_temperature”
time domain entity_id friendly_name friendly_name_str node_id value value_id value_index value_instance
1538169761539676928 sensor vision_zp3111_multisensor_4in1_temperature 311141 Vision ZP3111 Multisensor 4in1 Temperature 4 0 72057594110033940 1 1
nobody has a Monoprice 4-in-1 ? I have two of them and no values are saved in the influxdb (others entity are saved so the link HASS to Influxdb is working).
I rename the thermostat of the second to sensor.monoprice2_temperature, but it doesn’t show in the influxdb
Regards.
Louis
