I purchased two monoprice zwave shock / vibration sensors for a washing machine automation project. https://www.monoprice.com/product?p_id=15269
Inclusion for the sensor worked as expected.
When it’s included there are several new sensors as well as a binary sensor.
Here are the entities:
entities:
- entity: binary_sensor.vision_security_zs5101_shock_and_vibration_sensor_sensor
- entity: sensor.vision_security_zs5101_shock_and_vibration_sensor_alarm_level
- entity: sensor.vision_security_zs5101_shock_and_vibration_sensor_alarm_type
- entity: sensor.vision_security_zs5101_shock_and_vibration_sensor_burglar
- entity: sensor.vision_security_zs5101_shock_and_vibration_sensor_emergency
- entity: sensor.vision_security_zs5101_shock_and_vibration_sensor_homehealth
- entity: sensor.vision_security_zs5101_shock_and_vibration_sensor_sourcenodeid
type: glance
The only two values that seem to change are alarm_level and alarm_type
Open zwave seems to receive reports of shocks and 10 seconds later the cessation of the shock as expected, the cessation of the shock never shows up in the ui of home assistant.
You can see the logs here: https://pastebin.com/4AFTFPZi
I also cleaned them up a bit to remove things I think are not relevant:
1. 2019-07-28 12:08:26.314 Info, Node041, Received Basic set from node 41: level=0. Treating it as a Basic report.
2. 2019-07-28 12:08:26.314 Detail, Node041, Refreshed Value: old value=255, new value=0, type=byte
3. 2019-07-28 12:08:26.333 Detail, Node041, Received: 0x01, 0x10, 0x00, 0x04, 0x00, 0x29, 0x0a, 0x71, 0x05, 0x02, 0x00, 0x00, 0xff, 0x07, 0x00, 0x01, 0x02, 0x45
4. 2019-07-28 12:08:26.333 Info, Node041, Received Alarm report: type=2, level=0, sensorSrcID=0, type:Burglar event:0, status=255
5. 2019-07-28 12:08:26.333 Detail, Node041, Refreshed Value: old value=2, new value=2, type=byte
6. 2019-07-28 12:08:26.333 Detail, Node041, Refreshed Value: old value=255, new value=0, type=byte
7. 2019-07-28 12:08:26.333 Detail, Node041, Refreshed Value: old value=0, new value=0, type=byte
8. 2019-07-28 12:08:26.333 Detail, Node041, Refreshed Value: old value=2, new value=0, type=byte
1. 2019-07-28 12:08:37.247 Detail, Node041, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x29, 0x03, 0x20, 0x01, 0xff, 0x06
2. 2019-07-28 12:08:37.247 Info, Node041, Received Basic set from node 41: level=255. Treating it as a Basic report.
3. 2019-07-28 12:08:37.247 Detail, Node041, Refreshed Value: old value=0, new value=255, type=byte
4. 2019-07-28 12:08:37.266 Detail, Node041, Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x29, 0x09, 0x71, 0x05, 0x02, 0xff, 0x00, 0xff, 0x07, 0x02, 0x00, 0xa7
5. 2019-07-28 12:08:37.266 Info, Node041, Received Alarm report: type=2, level=255, sensorSrcID=0, type:Burglar event:2, status=255
6. 2019-07-28 12:08:37.266 Detail, Node041, Refreshed Value: old value=2, new value=2, type=byte
7. 2019-07-28 12:08:37.267 Detail, Node041, Refreshed Value: old value=0, new value=255, type=byte
8. 2019-07-28 12:08:37.267 Detail, Node041, Refreshed Value: old value=0, new value=0, type=byte
9. 2019-07-28 12:08:37.267 Detail, Node041, Refreshed Value: old value=0, new value=2, type=byte
Again, HA sees the initial shock. OZW sees the change from shock to normal state, but HA never changes after seeing one shock and the binary sensor never changes at all.
I can’t find the manual online but it says alarm version 1 for alarm type is 0x02 for vibration detected and 0x03 for tamper switch
Alarm level on is 0xFF
Alarm level off is 0x00
