Mopeka Integration vs. Mopeka ESP Home
Does anyone have a recommendation for using the Mopeka Integration vs Mopeka ESP Home? Any advantage to using one over the other?
Probably the biggest benefits of the HA integration are that not only is it a core integration, but you can use BT Proxies so you don’t have to necessarily deploy a new device to pick things up as well as the fact that they should just be automatically discovered by HA. It’s the only one I’ve used though, didn’t even know ESPHome had something specific to it.
