Mopidy plugin stopped working (error log)
Hello everyone,
The Mopidy plugin stopped working and I can’t get it to work again. Even after switching to a new RPi (3 -> 3+) and restoring a backup, it’s not doing what it should. Becuase of this, I can’t play audio files to the local AUX-port of my Raspberry Pi anymore.
I hope some has a solution. Re-installing the plugin doesn’t solve the problem.
This is the error log:
    yield
  File "/usr/lib/python2.7/site-packages/mopidy/core/playlists.py", line 66, in as_list
    playlists = future.get()
  File "/usr/lib/python2.7/site-packages/pykka/threading.py", line 52, in get
    compat.reraise(*self._data['exc_info'])
  File "/usr/lib/python2.7/site-packages/pykka/compat.py", line 12, in reraise
    exec('raise tp, value, tb')
  File "/usr/lib/python2.7/site-packages/pykka/actor.py", line 201, in _actor_loop
    response = self._handle_receive(message)
  File "/usr/lib/python2.7/site-packages/pykka/actor.py", line 295, in _handle_receive
    return callee(*message['args'], **message['kwargs'])
  File "/usr/lib/python2.7/site-packages/mopidy/m3u/playlists.py", line 69, in as_list
    for entry in os.listdir(self._playlists_dir):
OSError: [Errno 2] No such file or directory: '/share/mopidy/playlists'
ERROR    M3UBackend backend caused an exception.
  File "/usr/lib/python2.7/site-packages/mopidy/core/playlists.py", line 18, in _backend_error_handling
    yield
    yield
    yield
    yield
INFO     New MPD connection from [::ffff:[PI IP ADDRESS]:[PORT]
yield
