"more info" of Entity: Change from slider to box (number selector)
when I’m clicking on an entity on my dashboard, the more-info popup comes up, where I can change the value.
Is it possible to change that from the slider (current):
to a box (number selector) - then it’s easier via the mobile phone touch based.
Thanks,
Stefan
Click the cog icon in that card above your slider. What settings options are you given?
No, there is no way to change it.
Which integration is supplying the number entity?
It’s the “Stiebel Eltron ISG” (heat pump)
But the same question would for other integrations like for “BMW Conntected Drive” where I need to change the “Target SoC”:
which is also quite difficult to do with a slider, when I’m using a touch based device.
