Mosquitto addon installation error
I am trying since days to install Mosquitto addon and receive this error (only destination IP is changing from time to time).
I successfully installed others addons
File editor
Grafana
InfluxDB
Samba Backup
Terminal & SSH
But this one keep failing, DNS seems to resolve correctly and I can’t see firewall drop
I am ranning HA on a raspberry PI4 at the latest release.
This is the error:
Failed to install add-on
Can’t install homeassistant/aarch64-addon-mosquitto:6.1.3: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=6.1.3&fromImage=homeassistant%2Faarch64-addon-mosquitto&platform=linux%2Farm64: Internal Server Error (“Head “https://registry-1.docker.io/v2/homeassistant/aarch64-addon-mosquitto/manifests/6.1.3”: read tcp xxxxxxxxxx:60912->3.216.34.172:443: read: connection reset by peer”)
I’m having same error, did you fix at all?
Can’t install homeassistant/amd64-addon-mosquitto:6.1.3: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=6.1.3&fromImage=homeassistant%2Famd64-addon-mosquitto&platform=linux%2Famd64: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: read tcp XXX.XXX.XXX.XXX:44948->XXX.XXX.XXX.XXX443: read: connection reset by peer”)
I can install some addons but not all
yeah the issue was related to my VPN (Proton VPN), I can’t tell you exacly why, but disabling the vPN solved the issue
