Most of my zigbee devices stopped talking to me
Hi all.
I have 42 devices and a CC2531 - all been working a treat for many months.
Couple of days ago devices a little further from the coordinator stopped responding.
Logs have “no route” in them.
Bringing the devices closer does not seem to re-establish comms. This is what my map looks like…
I have restored a complete (VM) backup from a couple of weeks ago when it was working perfectly but it’s still the same so I’m wondering if something related to HW / environment?
eg loungelamp2 is phsically 2m from the coordinator right now but LQI is 0.
I have tried repairing and nothing, mqttexplorer doesn’t even see the interview.
I am running hass.io within Proxmox, CC2531 attached and a NanoCul dongle for Evohome control.
Core-2021.2.3 OS 5.11
when I try to toggle a no longer working device:
Zigbee2MQTT:error 2021-02-22 18:47:44: Publish 'set' 'state' to '0xb0ce1814030e5936' failed: 'Error: Command 0xb0ce1814030e5936/1 genLevelCtrl.moveToLevelWithOnOff({"level":0,"transtime":20}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (Data request failed with error: 'No network route' (205))'
Zigbee2MQTT:debug 2021-02-22 18:47:44: Error: Command 0xb0ce1814030e5936/1 genLevelCtrl.moveToLevelWithOnOff({"level":0,"transtime":20}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":false,"direction":0,"srcEndpoint":null,"reservedBits":0,"manufacturerCode":null,"transactionSequenceNumber":null}) failed (Data request failed with error: 'No network route' (205))
    at ZStackAdapter.<anonymous> (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:339:27)
    at Generator.next (<anonymous>)
    at fulfilled (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:24:58)
Zigbee2MQTT:info  2021-02-22 18:47:44: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"Publish 'set' 'state' to '0xb0ce1814030e5936' failed: 'Error: Command 0xb0ce1814030e5936/1 genLevelCtrl.moveToLevelWithOnOff({\"level\":0,\"transtime\":20}, {\"timeout\":10000,\"disableResponse\":false,\"disableRecovery\":false,\"disableDefaultResponse\":false,\"direction\":0,\"srcEndpoint\":null,\"reservedBits\":0,\"manufacturerCode\":null,\"transactionSequenceNumber\":null}) failed (Data request failed with error: 'No network route' (205))'","meta":{"friendly_name":"0xb0ce1814030e5936"},"type":"zigbee_publish_error"}'
Zigbee2MQTT:debug 2021-02-22 18:47:44: Received MQTT message on 'zigbee2mqtt/TankLights/set' with data 'ON'
Zigbee2MQTT:debug 2021-02-22 18:47:44: Publishing 'set' 'state' to 'TankLights'
Zigbee2MQTT:debug 2021-02-22 18:47:44: Received Zigbee message from 'LoganRoomPower3b1f81', type 'attributeReport', cluster 'haElectricalMeasurement', data '{"activePower":2794}' from endpoint 1 with groupID 0
Zigbee2MQTT:info  2021-02-22 18:47:44: MQTT publish: topic 'zigbee2mqtt/LoganRoomPower3b1f81', payload '{"linkquality":31,"power":2794,"state":"ON"}'
Zigbee2MQTT:debug 2021-02-22 18:47:47: Received MQTT message on 'zigbee2mqtt/bridge/config/devices/get' with data '1614019667062'
I see commetns about the number of devices and the CC2531, I’m waiting for one of the “reccomended” devices to come into stock and will try one of those but I want to say again that this has been working well for a long time!
