Motion activated lights automation problem after HA reboot
I rebooted HA when automation was running and lamp was on and never goes off. I activated automation with motion sensor and it’s still running.
It stuck at waiting for 1 trigger:
  - wait_for_trigger:
      - entity_id:
          - binary_sensor.lumi_lumi_sensor_motion_aq2_motion
        to: "off"
        for:
          hours: 0
          minutes: 0
          seconds: 30
        trigger: state
update: after some time it recovered itself
I wonder what if create 2 automations: first automation to turn lamp on trigger and second automation to turn off lamp :thinking:
I see the problem is aqara motion sensor, it stuck in Motion: Detected state after HA restart for about 10 minutes that’s why my automation doesn’t work.
I did another test, I rebooted HA when state was Motion: Clear and after reboot it worked right away!
Is there a way to set or reset item state on boot maybe?
Update 2: I set python_script integration and now can set state for motion sensor when HA starts.
I also now have two automations: first automation to turn lamp on trigger and second automation to turn off lamp.
The reason I need a second automation because I need to constantly monitor duration of Clear state, without dealing with states transition (from detected to clear).
alias: turn off lamp
description: ""
triggers:
  - type: no_motion
    device_id: <id_here>
    entity_id: <id_here>
    domain: binary_sensor
    trigger: device
    for:
      hours: 0
      minutes: 0
      seconds: 10
conditions: []
actions:
  - type: turn_off
    domain: light
    enabled: true
This trigger type: no_motion should turn off lamp after HA restart if its on.
In my testing trigger based on state changes doesn’t work for some reason.
Update 3: I rebooted HA and lamp was on and sensor state was clear. My automation failed.
I guess I need to create automation to turn off lamp when HA starts and go back to my original automation…
