I’m using this automation with some PIR sensors and it works pretty good. But now I have the problem and want to make the light only go on when it’s dark. So I have a new PIR/Lux sensor which reports the current Lux AFTER motion is detected. If I use motion sensor first, light will not trigger, because Lux is still from last state, when Light was on. So I need to “delay” before condition or need to trigger on lux change.
I already tried without luck:
- platform: numeric_state
entity_id: sensor.pir_kuche_beleuchtungsstarke
below: 600
- platform: state
entity_id: binary_sensor.pir_kuche_bewegung
to: "off"
for:
minutes: 5
- target:
entity_id: light.kuchenwand_licht
action: light.turn_{{ binary_sensor.pir_kuche_bewegung }}
mode: single
(Error rendering service name template: UndefinedError: 'binary_sensor' is undefined)
That’s the problem if you don’t have the right LUX value before the motion is detected.
If you want to control lights based on whether it’s dark or not, you will need a sensor that reports this, no matter what.
I have Philips Hue motion sensors and they update quite fast, even though not that precise.
For really reliable light switching, based on luminance having a sensor outside or in front of a window is your best option.
I have been looking for some time for this to my liking but have not found it yet.
Just because it’s dark outside, doesn’t mean it’s dark in the kitchen or hallway. For example if I walk down the stairs, there is already light at ground floor, so sensor is reporting 800lux after motion detection and I don’t need extra light at night. So I would need one sensor for motion and one for luminous, which needs to be connected to wire and update every second… This would be pretty bad solution.
Would be better if there is something like
If motion on/off, wait 1 second, switch based on luminous and state from trigger (or leave light on of trigger was on and not off after 2 minutes).
I use a Fibaro motion sensor for this. Reports motion, temperature, lux, but all as independent measurements. For lux and temperature, the user can set the reporting interval.
Okay, so there is no natural light where you want the detection.
Why don’t you just use the state of those lights, on/off/brightness, to decide whether you want that extra light to turn on (or not) so you don’t need an additional sensor.
Well, let’s say there is natural light, but not only that or not enough. For Example:
Over a normal, sunny day, there is enough light in the entrance area. So I don’t want these lights go on.
If it’s really cloudy or in the evening, it’s to dark, so lights need to go on.
If there is light on at the stairs to first floor or dinner table, I also don’t need light, so it should stay off.
That’s why I use a pir sensor with lux at this area (you get them for 3,69€ at Aliexpress Choice bundle). Only downside: Lux get reportet AFTER motion detection. So this is the Problem:
Motion is off ; Lux 1000
Motion on is triggert → Lux 1000 → Light stays off
Lux gets updated → 900
After 1 Minute Motion off is triggert → Lux 900
Lux gets updated → 950 (because of light)
After 2 Minutes without Motion → Light goes off → Lux still 950
Motion on is triggert → Lux 950 → Light stays off
Lux gets updated → 300 => I want the light to be on
I’m trying tonight with more complex script, hope that works, unless @tom_l comes up with a smarter way.
Well, then doing something as figured out yourself, wait a little delay after the trigger to use the value of the LUX sensor to decide what the light has to do.
On top of that, you might move the sensor to a more strategic place - if possible - to compensate that delay.
But, to be fair, for the price of those sensors you cannot expect more.
Are they reliable for motion detection, no false positives?
