Motion sensors getting stuck in occupied
I moved house and restarted my home assistant from fresh. But I am having an issue where the motion sensors I used to use, are typically getting stuck as occupancy = detected.
It seems completely random that it happens, but seems to be happening more and more.
They worked correctly on first set up for a couple weeks, and not sure if it was after an update they started going worse or just coincidence.
They are mostly PIR 24Ghz human presence sensor (ZG-204ZM)
I have tried changing batteries, changing to various settings. Set it to its default settings when they go in.
I change the detection right down and it seemed like it worked for a couple days then come out one morning to the light still being on.
Using ZQMTT with them.
I have no idea where to start with trying to get these working correctly again. I also got a couple SNZB-06P presence sensors that are usb powered to see if they are a bit more reliable, but it also makes it harder to place them in the right spots.
Any help appreciated.
Hi Leon, have a look at this: Zigbee Battery Presence Sensor ZG-204ZM Review | SmartHomeScene
especially at the 'Update' of that article and maybe at the comments but I didn't bother to read them.
You left your rosary beads behind. :slight_smile:
What is different? Wall construction, log entries, sensor placement, external interference, battery levels, misconfiguration?
Thanks for the article link. Some useful info there.
Everything is different. But they motion devices still have a decent signal and their defaults should work.
Should be less interference here if anything, went from a new apartment into an older town house with a lot less stuff around.
I.e. right now they are showing presence = true, motion state large and no one has been in that room for over 15mins.
The logs dont really tell much, they just say the same thing as the device. Its reporting that its in use with large motion.
No idea where to start trying to debug it to try and find something useful.
Is your zigbee network OK (stable, no interference)?
Does Z2M show the same info for these sensors as HA?
Look at the connection statistics in Z2M.
Did you check the Z2M GH issues?
Other than that, I cannot come up with any advice...
Yea Z2M and HA show the same info.
How can i check if it has interference?
Saw some issues related to these devices, Tried rolling back to a much older version but that did not work, too old :frowning:
Have a look at this: Zigbee network optimization: a how-to guide for avoiding radio frequency interference + adding Zigbee Router devices (repeaters/extenders) to get a stable Zigbee network mesh with best possible range and coverage by fully utilizing Zigbee mesh networking
