IP motioneye ip camera not working - no picture - no error
configuration
- platform: mjpeg
mjpeg_url: http://192.168.0.1:8081
username: myuser
password: mypass
motioneye config:
configuration
- platform: mjpeg
username: myuser
password: mypass
motioneye config:
Nevermind. I find new beter solution with KERBEROS(has integrated mqtt) + NODE-RED
LINK: https://doc.kerberos.io/
mjpeg camera now works.
mqtt motion trigger:
- platform: mqtt
state_topic: "postor-sec/cam-front/motion"
payload_on: "1"
payload_off: "0"
device_class: motion
NODE-RED:
[{“id”:“deca11b4.e1364”,“type”:“mqtt in”,“z”:“ca1dcae1.cd6ba8”,“name”:"",“topic”:“postor-sec/cam-front/video”,“qos”:“2”,“broker”:“de7daeba.05146”,“x”:195.27778625488278,“y”:696.6666666666665,“wires”:[[“94cd9fb6.e1076”]]},{“id”:“94cd9fb6.e1076”,“type”:“change”,“z”:“ca1dcae1.cd6ba8”,“name”:“motion.cam-front”,“rules”:[{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“postor-sec/cam-front/motion”,“tot”:“str”}],“action”:"",“property”:"",“from”:"",“to”:"",“reg”:false,“x”:528.8888549804688,“y”:695,“wires”:[[“be6ab7d9.d00308”,“1005afd5.494bc”]]},{“id”:“be6ab7d9.d00308”,“type”:“trigger”,“z”:“ca1dcae1.cd6ba8”,“op1”:"",“op2”:“0”,“op1type”:“nul”,“op2type”:“str”,“duration”:“5”,“extend”:false,“units”:“s”,“reset”:"",“bytopic”:“all”,“name”:"",“x”:813.7221717834473,“y”:677.6666374206543,“wires”:[[“1005afd5.494bc”]]},{“id”:“1005afd5.494bc”,“type”:“mqtt out”,“z”:“ca1dcae1.cd6ba8”,“name”:“Publish MQTT Message”,“topic”:"",“qos”:“0”,“retain”:“true”,“broker”:“de7daeba.05146”,“x”:1190.3888206481934,“y”:749.3332977294922,“wires”:[]},{“id”:“de7daeba.05146”,“type”:“mqtt-broker”,“z”:"",“name”:“MQTT Broker”,“broker”:“192.168.0.200”,“port”:“1883”,“tls”:“357b403.fcb6dc”,“clientid”:"",“usetls”:false,“compatmode”:true,“keepalive”:“60”,“cleansession”:true,“birthTopic”:"",“birthQos”:“0”,“birthPayload”:"",“closeTopic”:"",“closePayload”:"",“willTopic”:"",“willQos”:“0”,“willPayload”:""},{“id”:“357b403.fcb6dc”,“type”:“tls-config”,“z”:"",“name”:"",“cert”:“fullchain.pem”,“key”:“privkey.pem”,“ca”:"",“certname”:"",“keyname”:"",“caname”:"",“servername”:"",“verifyservercert”:false}]
