Motorcycle tracker with home assistant integration
Since I have GoogleFI as my cellular provider they add up to 5 free data SIM’s. I wanted to use one for a DIY motorcycle (or anything else) GPS anti-theft tracker and alarm built on an ESP32 with cellular connectivity, motion-triggered theft detection, and full Home Assistant integration over MQTT.
Go to GitHub - puravida13/moto-trak · GitHub for project files.
Hardware Used
  • LilyGo T-SIM7000G - ESP32 dev board with an onboard SIM7000G modem (LTE-M/NB-IoT + GPS)
  • MPU6050 - accelerometer/gyro, used as the motion-triggered theft sensor
  • PN532 - NFC reader for tap-to-arm/disarm (optional - firmware detects its absence at boot and falls back to MQTT-only arm/disarm)
  • 21700 Li-ion cell (a high-drain cell is strongly recommended - the SIM7000 modem draws current spikes up to ~2A during LTE transmit/registration)
  • A bulk capacitor across the main battery input, to help buffer those modem current spikes
  • 16MB flash (used for a 3MB OTA-capable app partition + 9MB LittleFS partition for debug logging - see partitions.csv)
Features
  • Cellular GPS tracking over LTE-M, published to MQTT (tested on Google Fi’s h2g2 APN, configurable for any carrier)
  • Motion-triggered theft alarm - MPU6050 wakes the device from sleep; if armed, motion immediately triggers a theft alert and starts periodic GPS pings
  • NFC tap arm/disarm, with MQTT ARM/DISARM as a parallel/fallback control path
  • Recovery mode - if a theft alert isn’t cleared within 30 minutes, the device drops into a longer-interval GPS “recovery ping” cycle to conserve battery while still reporting location
  • Aggressive power management - ESP32 light sleep with a 5-minute idle timeout, hourly heartbeat wake (30-minute in recovery mode), and hard failsafe timeouts so the device never gets stuck awake
  • Battery monitoring with low/critical voltage thresholds and a validity guard against bogus ADC readings
  • On-device debug logger - a rotating LittleFS log (boot reasons, sleep/wake events, MQTT/LTE failures, theft triggers, telemetry) that survives reboots/crashes, independent of MQTT connectivity, for real post-mortem diagnosis
  • Full Home Assistant integration - native alarm panel entity, device tracker, battery/signal sensors, and dashboard controls to arm/disarm, locate, and pull/clear the debug log remotely (see home-assistant/)
Implementation
Connectivity
MQTT over the SIM7000’s cellular data connection, using Adafruit IO as the broker. Feed topics are all built from a single SECRET_MQTT_USER value in secrets.h, so they stay consistent automatically:
Feed Purpose
motogps/csv GPS fixes: speed,lat,lon,alt
motobatt Battery voltage, in millivolts
motosignal Cellular signal quality (CSQ)
motostatus Human-readable status/event strings
motocmd Inbound commands (ARM, DISARM, GPS, DUMPLOG, CLEARLOG)
motolog Chunked debug-log dump, published on DUMPLOG
LED indicator
The only feedback available without a phone in hand - one onboard LED, several distinct patterns:
Pattern Meaning
Off Disarmed and idle
Off (held low) Light sleep
4 quick flashes, then solid on Boot or wake-up sequence starting
Brief blink every ~5 seconds Armed and idle (heartbeat pulse)
Fast continuous blink Theft alarm triggered, or NFC learn mode active
Fast blink for 10 seconds after an armed wake Waiting for an NFC tap (grace period) before deciding theft vs. legitimate access
Two quick flashes Command confirmed: now armed
One long flash (~800ms) Command confirmed: now disarmed
Power/sleep cycle
The device spends almost all of its time in ESP32 light sleep (not deep sleep - setup() doesn’t re-run on a normal wake, so armed/theft state persists across wake cycles without needing RTC-memory tricks). It wakes on:
  • A GPIO interrupt from the MPU6050 (motion, only enabled while armed)
  • A GPIO interrupt from the PN532 (NFC tag present, if the reader is installed)
  • An hourly timer (30 minutes while in recovery/theft-tracking mode)
A true reboot (setup() re-running) only happens on power-on, a physical reset, a brownout, or a firmware crash/watchdog reset - which is also exactly what the on-device debug logger’s BOOT events are for tracking.
Debug logger
A CSV-formatted log (millis,batteryV,freeHeap,TAG,message) stored on a dedicated LittleFS partition, capped in size (LOG_MAX_BYTES in the firmware) and rotated to keep two generations. It’s deliberately not wiped on every boot, so a crash/brownout reboot doesn’t destroy the evidence of what led up to it. Pull it over MQTT with the DUMPLOG command (chunked, rate-limited to stay under your MQTT broker’s throttle), or dump it to serial with the dumplog command over USB. Clear it with CLEARLOG (over MQTT) or clearlog (over serial).
See home-assistant/ for ready-to-use config: MQTT entities (sensors, device tracker, native alarm panel, switch, buttons), automations (theft/low-battery/geofence alerts, debug-log dump plumbing), a toggle script, and a dashboard card. That folder’s README-style comments explain what needs to be customized (your Adafruit IO username, notification service, etc.) - it’s written to be dropped into someone else’s HA instance, not just mine.
Getting Started
Firmware
  1. Copy secrets.example.h to secrets.h and fill in your Adafruit IO username/key. secrets.h is gitignored - it never gets committed.
  2. Install the ESP32 board package and these libraries in the Arduino IDE: Adafruit PN532, Adafruit MPU6050, Adafruit Unified Sensor, PubSubClient, TinyGSM.
  3. Board settings: ESP32 Dev Module, Flash Size 16MB, Partition Scheme Custom (picks up partitions.csv from the sketch folder automatically).
  4. Update apn in the sketch for your carrier if you’re not on Google Fi.
  5. Compile and flash.
Home Assistant
See home-assistant/ for the config files and setup notes.
