Mount smb share paperless ngx consume
Hi community,
I’m new at homeassistant but I think I have some linux experience. However, I have a homeassistant installation and added the Add-On paperless NGX. But I do not want to use the consume folder from the local filesystem. What I would like to to now is, to mount a smb share, which is located on my local NAS and mount it at the mountpoint /share/paperless/consume. This works so far. But paperless does not use this mountpoint. It seems it sees still the local filepath /share/paperless/consume. So when I copy a .pdf file into the mounted consume folder, paperless does not recognize it. If I unmount the smb share and I copy a .pdf file into consume, it works.
But what I’m doing wrong? Is there somehow a other instance, where paperless is running?
Hope someone has an idea.
Thank you in advance for your help!!!
