Mounting the homeassistant folder
Hi, I’m working on Manjaro, HA is installed on RPi3. I want to make the /home/homeassistant/.homeassistant folder public and connect to my system. When you mount it, it works, but the files are not displayed.
Rights to .homeassistant 774
Mount with a PI account that is part of the homeassistant group and has access to the files. Tell me, why do not I see them when editing?
I use samba to access my home assistant directory. The relevant part of /etc/samba/smb.conf looks like this:
[homeassistant]
path = /home/homeassistant/.homeassistant
writeable = yes
guest ok = yes
create mask = 0644
directory mask = 0755
force user = homeassistant
I use Ubuntu on all my other systems, and can access the directory from the file manager
Excuse me, but how do you mount the directory, after sudo mount // hassbian / homeassistant / mnt / homeassistant requires a password from sudo, but then runs a password from root @ hassbian, why does this happen?
I don’t mount the Home assistant folder, I just access it from the file manager in Ubuntu and Windows in this case, but on another raspberrypi, when I manually mount a samba share, I just use my users password.
sudo mount -t cifs //willy/music ~/Music
Password for root@//willy/music:  ********
pi@raspberrypi:~ $ df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        30G  3.9G   25G  14% /
devtmpfs        213M     0  213M   0% /dev
tmpfs           218M     0  218M   0% /dev/shm
tmpfs           218M  3.1M  214M   2% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           218M     0  218M   0% /sys/fs/cgroup
/dev/mmcblk0p1   42M   21M   21M  51% /boot
tmpfs            44M     0   44M   0% /run/user/1000
//willy/music   7.3T  3.0T  4.3T  41% /home/pi/Music
