Hello, I have a Hue outdoor sensor managed by the Hue bridge - marked. It is visible in a Dashboard in HA via Hue Integration. Now I want to move it (like many other Hue Devices in the near term) to HA with ZHA integration. I want to keep 1yr+ of Temperature Data. So it is not just a rename (which is described here) but the Entity will disappear from the Hue Integration when I delete it from the Hue Bridge (at least this is what I assume). What could be a good approach?
type: vertical-stack
cards:
- graph: line
type: sensor
>>> **entity: sensor.bwm_mull_temperatur**
detail: 1
- graph: line
type: sensor
entity: sensor.feusen_terasse_vorne_temperatur
detail: 1
name: Terasse vorne Temperatur
- graph: line
type: sensor
entity: sensor.feusen_terasse_vorne_luftfeuchtigkeit
detail: 1
name: Terasse vorne Luftfeuchtigkeit
