Hello all,
I’m running the Home Assistant Operating System on an ODroid N2+ with MotionEye.
I added a 1TB MicroSD card and moved the data drive to it.
The MicroSD appears to have died several months later (probably due to the MotionEye I/O), CRC error, OS repair fails 3 times each boot.
It is now locked to read only, I have tried to repair it on several Linux systems to no avail.
I added an external 2TB surveillance rated hard drive via USB.
I then tried moving the data drive to the new USB drive. It begins the process, creates the partition, but it never actually moves the data or changes the location of the data drive in the settings.
Thank you for any thoughts you may have on this.
