Move DB files and Logs to Thumb Drive on Pi
Some great stuff by @briancribbs and @Tinkerer that I took as my own. :slight_smile:
Extend the life of your SD Card…
I personally have moved /tmp to RAM and symlinked the hass log file to /tmp/home-assistant.log. I do lose the log file on reboots and power cuts, but this way there’s absolutely no wear on my SD card. I also use an external SQL database on a different host with proper hard drive.
I tried putting my database on the thumb drive this morning, but looking at the amount of io it saved, I’m not sure it is worth the effort.
$ iostat
Linux 4.9.41+ (raspberrypi)     24/10/17        _armv6l_        (1 CPU)
avg-cpu:  %user   %nice %system %iowait  %steal   %idle
          14.27    0.00    2.55    1.48    0.00   81.70
Device:            tps    kB_read/s    kB_wrtn/s    kB_read    kB_wrtn
mmcblk0           3.81        33.90        37.77   35386809   39434048
sda               0.07         0.01         0.32       9681     338957
Is this unusual?
Mine is a little different. I have a LOT of devices though in HA.
pi@Carlo-Pi:~ $ iostat
Linux 4.9.35-v7+ (Carlo-Pi)     10/24/2017      _armv7l_        (4 CPU)
           8.06    0.00    6.84    2.04    0.00   83.05
mmcblk0           0.99         3.88         9.63     293242     728092
sda               7.53         0.05        85.47       3770    6463028
I’ve also pushed my TTS cache to the flash drive as well.
Would you mind doing a tutorial on this? Sound sensible! Thanks
There’s plenty of tutorials online which I used. Here’s one:
P.S.: keep in mind that when updating HASS you’ll need larger /tmp - I use 150MB. For day to day operation a 50MB /tmp is sufficient.
