Move from configuration .yaml to the config editor in HA
when I enter the config tab HA says that “my editor is inactivated since the configuration is stored in configuration.yaml”
What can I do about this?
Can I migrate config or do I need to start all over?
I hope someone can help…
Do you mean to get to the General Configuration?
You just need to remove/comment from your configuration.yaml file some of the settings under the homeassistant section;
Name
Longitude
Latitude
Elevation
Timezone
Unit system
When you renter your location in the general configuration, you’ll need to zoom out on the map about 10 times as it puts you really close up, in the middle of the ocean somewhere!!
I think that has recently been changed. I just installed a “test” hassio and the UI configuration started me out near Amsterdam.
